Old 11-21-2023, 10:36 AM   #1
GasWorksGarage
Default 1959 Edsel 361 Lifters
Anyone know the part number for non adjustable hydraulic lifters?
Are they the same as the lifters used in adjustable rockers?
Thanks in advance
GasWorksGarage is offline   Reply With Quote
Old 11-21-2023, 11:18 AM   #2
KULTULZ
KULTULZ's Avatar
Arrow Re: 1959 Edsel 361 Lifters
If your FE 361 is original, it came (should) through with 1.82"L lifters and were the same for fixed or adjustable rockers (1958).
EDSEL had separate parts cataloging but it should ... ... be the same as the 2"L lifter was not available until 11/18/63. They went back to 1.82"L in the 1965 model run.
C8AZ 6500-A (1.82"L) was the FINAL SERVICE PN.
C8AZ 6500-B were the FORD anti-pump-up lifters ...
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 11-21-2023, 11:42 AM   #3
GasWorksGarage
Default Re: 1959 Edsel 361 Lifters
Thanks for the info, C8AZ 6500-A is what I came up with but wasn't 100% sure.
