Old 09-06-2015, 02:17 PM   #1
glenn in camino
glenn in camino's Avatar
Default Snyders rumble hinge fix
In the 2010 Snyders catalog, page A177, there is the following statement under the rumble seat hinge kit .
When installing new hinges on your deck lid, it is sometimes necessary to use flat washers to shim between the hinge bracket and the deck lid.
Can any one explain this. I guess Snyders knows that they don't fit.
glenn in camino is offline   Reply With Quote
Old 09-06-2015, 02:54 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Snyders rumble hinge fix
I think it's in order to "center" the deck lid.
Paul in CT
Old 09-06-2015, 04:29 PM   #3
Larry Jenkins
Call Tom Jordan at Snyders. He'll give you a straight answer.
larry
Larry Jenkins is offline   Reply With Quote
Old 09-06-2015, 05:49 PM   #4
Steve Plucker
Glenn,
Did you call Ron? He has my original hardware.
Pluck
Old 09-06-2015, 07:27 PM   #5
glenn in camino
I'll call them on Tuesday.
Old 09-06-2015, 08:47 PM   #6
Logan
Logan's Avatar
Every car and body are different. If one lid fits on one car, simply moving it over to another car doesn't mean it'll fit the new car. You have to make things fit nicely on model a's, therefor adding and removing shims in places that may need it. They weren't perfect gaps from the factory, but you can get them really really close.
Cowtown A's
Logan is offline   Reply With Quote
