06-17-2022, 07:29 AM | #21 | |
Re: Transmission pops out of second
I was surprised on how tight some of the tolerance are and thank goodness Mac VP sells thrust washers of varying thicknesses to help get things on the low side of spec. I'm not familiar with this trans, but I'm thinking you'll need to go through it again unfortunately. |
06-21-2022, 10:08 AM | #22 |
Just an update, trans is back out and the syncro assembly seems a little more beat than I thought upon initial inspection. The one spring keeps popping out of it, and the three blocker bars look fairly worn. Also it doesn't slide on the hub smoothly. I sourced a NOS synchronizer assembly. While I wait for that I'll double check my clearances on everything else...
07-05-2022, 11:50 AM | #23 |
Follow up repair, I wound up replacing the second gear with another and replaced the synchronizer assembly with a NOS replacement. Reassembled and double checked tolerances and it's good. I'm not really sure where the fault was since I replaced everything in question. And yes we now know Zephyr gears will work in the '49-50 Merc overdrive case!
07-05-2022, 11:58 AM | #24 |
Please let us know if after a bit of break in, does it stay in second gear upon deceleration from higher RPMs? We're all trying to do our best with these old cog-boxes and parts are getting harder to find!
07-05-2022, 12:15 PM | #25 | |
Everything I used was NOS. Everything: case, clusters, bearings, top, shafts, rails, forks. I have approx. 500 miles on it and it still shifts firmly and crisply. I've been purposely decelerating hard in 2nd to see if it will pop out and the stick stays firmly in place. Doesn't shake around like I've seen some boxes that are a tad worn. Fingers crossed I got it right, but I'm happy with the rebuild. I am going to be doing a 26 tooth LZ box build up with winter and may swap it in for the 28 tooth box that's in there now. I'd like to get more legs out of 1st, but I'm also going to be installing a quick change so that will help with gearing as well. |
