Old 11-29-2019, 10:57 PM   #1
Ian1932
Ian1932's Avatar
Default Really Cool Old & New Stuff
Radiator closed up since 1951. Old new parts. This stuff has been tucked away for a long long time...Some new shocks from Bill Stipe...
Anyone know what the item is that says 1933 on it?
Ian1932 is offline   Reply With Quote
Old 11-29-2019, 10:58 PM   #2
Ian1932
Ian1932's Avatar
Default Re: Really Cool Old & New Stuff
more
Old 11-29-2019, 11:06 PM   #3
pete rose
Wow, nice
Pete
pete rose is offline   Reply With Quote
Old 11-29-2019, 11:19 PM   #4
Tim Brown
Tim Brown's Avatar
Would you sell me the lock cylinder with the 2 keys...?
Tim Brown is offline   Reply With Quote
Old 11-30-2019, 06:11 AM   #5
32Bee
I'd say the item with 1933 embossed on it is part of a tool to be used to remove
and install rivets on brake linings.
Peter
32Bee is offline   Reply With Quote
Old 11-30-2019, 08:46 AM   #6
jimTN
New radiator is not an original Ford, Ford did not make honeycomb radiators. Still a very good radiator. No wonder 32-4 parts dried up around here after the 50s, looks like you got them all.
Old 11-30-2019, 09:13 AM   #7
TJ
TJ's Avatar
Peter
I agree with you assessment.
Old 11-30-2019, 07:23 PM   #8
DavidG
DavidG's Avatar
As jimTN idicates, the radiator is NORS, not NOS. You could put it to good use on your roadster and hopefully have a straight fin and tube original for your coupe project.
Old 12-03-2019, 06:37 AM   #9
Ian1932
Ian1932's Avatar
Thats a bummer...I will put that in the roadster. I found 2 more, which i believe are for a B...I think ill leave them both where they are until the times comes...I see one more but i cant get to it...
Old 12-04-2019, 08:34 AM   #10
rockfla
rockfla's Avatar
If they are for a "B" they will not work as they "should" only have "One" "inlet" and "outlet". SO not sure what you trying to indicate by "B" but on here a "B" is 4 Cyl.
Old 12-04-2019, 08:58 AM   #11
Ian1932
Ian1932's Avatar
I meant i think they are for a model "B" / 4cyl, meaning they are probably not what i need. I have another that i cant get to because i will need to move half of the earth to do so. I am hoping that the one "i cant get to" and do not have a picture of is for a V8...
I have another 32' that will be bone stock. David was just saying i could use the repo in the roadster and hopefully i had another true Ford rad for the other car (coupe) that will be stock.
