02-04-2019, 11:16 PM | #21 |
Re: 37 V8 - Thermostat anchor??
If you look close to mine you'll see a zip tie, just chokes the hose, I had [and still do] it like that for some time but use the wire method too.
"Came too close to dying to stop living now!" |
02-04-2019, 11:30 PM | #22 | |
Pretty low tech good solution. I believe an Old henry post. he always had a way to get it done. Traveled a lot and did some questionable fixes. This was not one of them. He is mia now. Flying RV planes now to my knowledge. Last edited by Tinker; 02-04-2019 at 11:43 PM. |
02-05-2019, 10:04 PM | #23 |
Delete.
Ignorance of the laws of physics does not mean they do not apply to you. Last edited by 29AVEE8; 02-05-2019 at 10:19 PM. |
02-05-2019, 10:50 PM | #24 |
The wire method works well. I have used it for years.
02-06-2019, 09:51 AM | #25 |
That style was only on Carriers.
02-07-2019, 05:33 PM | #26 |
02-07-2019, 05:39 PM | #27 |
You could also try one of these > https://www.jegs.com/i/JEGS/555/53260K1/10002/-1
View All JEGS In-Line Thermostat Housing JEGS In-Line Thermostat Housing Kit with 180 Degree Thermostat Part Number: 555-53260K1 $28.97 In-Line Thermostat Housing Kit Includes:(1) In-Line Thermostat Housing 555-53260 (1) 180 Degree Thermostat 555-53221 (2) Hose Clamps 555-16055
02-07-2019, 06:07 PM | #28 |
supereal>>> secure them with a hose clamp placed around the hose just over the stat>>>
Old Henry>>>hold the stat in place is put a hose clamp above it and crank it down>>> TonyM>>> I think some one on FordBarn suggested using a second clamp to hold the thermostat in place. This is what I did. No more problem.>>> mit31>>>The only thing I can think of is a hose clamp above the stat>>> 8^) Jack E/NJ |
