Old 05-19-2019, 10:25 PM   #1
chrs1961815
chrs1961815's Avatar
Default Correct Sediment bulb Mounting Hardware
What is the correct nut and washer for mounting the cast iron sediment bulb? I checked the hardware book but had no luck. I have seen originals with different hardware than what the vendors sell, which is a zinc plated nut and teethed lock washer. Is that correct? I ordered this exact set and had to file the lockwasher down to make it fit on the stud. Also, the nut didn't want to go on compared to the original.
https://www.brattons.com/sediment-bu...ck-washer.html
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 05-19-2019, 11:13 PM   #2
Dan Partain
Dan Partain's Avatar
Default Re: Correct Sediment bulb Mounting Hardware
Here's a photo in the for sale section
https://www.fordbarn.com/forum/showt...ht=fuel+filter
Dan Partain is offline   Reply With Quote
Old 05-20-2019, 07:27 AM   #3
jak
check this link
jak is offline   Reply With Quote
Old 05-20-2019, 07:36 AM   #4
chrs1961815
Originally Posted by jak View Post
That is the link I posted.
Old 05-23-2019, 01:51 PM   #5
katy
katy's Avatar
I just checked an original that I have in the shop, thread is 3/4-16 NF, the lockwasher is missing but IIRC it is an internal star washer.
Old 05-23-2019, 09:00 PM   #6
F.M.
The correct large washer used can be seen in post #2.. Brattons is wrong.
F.M. is offline   Reply With Quote
Old 05-23-2019, 10:26 PM   #7
Benson
Benson's Avatar
I know that OP did not ask but ...
The second washer that appears in post 2 is the original washer made of lead ... to seal the BRASS DRAIN piece for drain shown in the photo.
Benson is offline   Reply With Quote
Old 05-24-2019, 09:32 AM   #8
Joe K
Joe K's Avatar
The second washer that appears in post 2 is the original washer made of lead ... to seal the shutoff for drain.
Dan Partain's is how I remember mine. (March 1929) I think the star washer (Bratton pix) is from the glass version. At least all the glass versions I have seen have this.
For the cast iron, the nut is "different" and kinda heavy for the application, (lighter than an SAE Nut) the lockwasher is unusual in the angled ends.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 05-24-2019, 10:21 AM   #9
katy
katy's Avatar
The original nut is ABOUT 1/4" thick, takes a 1-1/8" wrench.
Old 05-24-2019, 05:29 PM   #10
F.M.
Instead of asking a question like that, why not just go to E-Bay and see one for sale & buy it.. Plenty of books to show you what is correct, or other peoples cars.. When you buy from the Reproduction Sellers dont "expect" it to be correct in looks, size, or fit..
