11-07-2022, 04:07 PM | #21 | |
Re: Crankcase ventilation on a supercharged engine
Teflon buttons to keep the wrist pins in place have been in a few of my flathead builds over the years. Also added teflon buttons into the piston skirts back when I was using Jahns brand cast pistons. Those engine's would rev really nicely but I'm not sure if it helped with economy. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
11-07-2022, 04:46 PM | #22 | |
I see that your avatar engine has a blower. Have you used this oil pan vent with a blower? I've thought about doing that too and even to plumb it so the breather was high up like around the top of the heads. Glenn |
11-07-2022, 05:46 PM | #23 |
Yes it is on that engine, has been together at least 30 years.
11-07-2022, 05:47 PM | #24 |
Great, it must be fun!
Glenn |
11-10-2022, 04:52 PM | #25 |
"I know that a guy must take his crankcase ventilation pretty seriously to spring for one of these "SPENDY" adjustable PCV Valves. Does it deliver anything like the results that you had hoped for, Glenn?"
I went for a good test ride today and the Wagner PCV is really doing the job. No oil was pushed out today! Glenn |
