02-10-2022, 06:27 PM | #1 |
reboring a sleeved cylinder question
i have an engine that has all ready been sleeved, it was bored last time to 0.080 and now the sleeve needs to be bored to .100"
i am guessing the sleeve is from snyders but am unsure. and i don't have the current od on the sleeve. any ideas on a max bore on a sleeve? or minimum wall thickness on the sleeve? thank you
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." Last edited by old ugly; 02-10-2022 at 07:32 PM. |
02-10-2022, 07:10 PM | #2 |
Re: reboring a sleeved cylinder question
I have the same type question with a $6K engine rebuild that developed a crack about an inch up from the bottom of #3. I'd like to sleeve it to the same bore, .060 over, as the other three, but want the crack repaired first. I have been told that there are people satisfactorily welding cast iron heads that should also be able to weld the crack. Is that fact, or is speculation? Like to find someone near the SF Bay area to tackle it.
Ace Mechanic with steamer. Lots of steam. |
02-10-2022, 08:02 PM | #3 | |
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
02-10-2022, 10:42 PM | #4 |
I am probably going to get many opposing views about welding cast iron but the fact is cast iron cannot be welded. Metallurgically cast iron is not the same as wrought of forged iron based alloys. Cast iron lacks the properties needed for complete fusion when exposed to various welding methods. Cracks in cast iron can be braised but if the repaired area is exposed to large mechanical loads or thermal cycling it will ultimately crack again. Mechanical stitching is the only method for repairing cracks in cast iron. Maybe it's time to look for another block.
02-10-2022, 11:30 PM | #5 |
Look up "Loc-N-Stitch" and they are right out in your area - California. I have seen
some of their repaired work at the Hot Rod & Restoration shows and it was amazing. The best part of it is they can repair your block or you can do it yourself, but either way it will be repaired correctly and then you can have it sleeved and then bored out to your .060 size piston. Your rebuilder should have heard of them, but if not then check them out yourself. Good luck..... |
02-11-2022, 06:18 AM | #6 |
02-11-2022, 08:25 AM | #7 | |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
left on each side of the sleeve. This is what the sleeve manufacturers recommend. |
02-11-2022, 09:37 AM | #8 | |
thank you
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
02-11-2022, 09:55 AM | #9 | |
sleeve od ----------------4.063" stock bore + 100 over - --3.976" difference ------------------0.087" divided x2------------------0.0435" i think 1/16" is .0625
02-11-2022, 05:53 PM | #10 |
Yes 1/16" is .0625" and that's the minimum that the sleeve manufacturers recommend; at .043" the sleeve will fail.
02-11-2022, 10:16 PM | #11 | |
ou
02-12-2022, 04:28 PM | #12 |
Amen on the "Loc-N-Stich" people. We have had a 100% success rate with them.
If its not a very big crack you can call ahead and make an appointment and they'll do it while you wait. On the sleeve, if it does get too thin L.A. Sleeve in Los Angeles can make you anything you want. You can make it larger so it won't be so thin and even have the I.D. closer to you finish bore so as not to have to bore .100 out of it when you get it. |
