Old 02-06-2019, 10:50 AM   #1
29FordRoadster
Default Valve clearances for Cragar Head
Will somone please tell me the valve clearances for a Cragar head on a Model A engine.
29FordRoadster is offline   Reply With Quote
Old 02-06-2019, 11:29 AM   #2
briphaeton
Default Re: Valve clearances for Cragar Head
Depends on your cam grinders recommendation.
briphaeton is offline   Reply With Quote
Old 02-06-2019, 12:27 PM   #3
Jim Brierley
Clearance is determined by the cam being used. If you think it has a stock cam, set them at .014" intake and .016" exhaust. If the head has it's original rocker arms, they are 1.25:1 ratio, so valve clearance is 1.25 times stock settings. You could also check the present clearances and assume they are close to what they should be, and adjust any that are far off. Now might be a good time to re-torque the head.
Old 02-06-2019, 04:02 PM   #4
29FordRoadster
Thank you briphaeton and Mr. Brierly for the information. Your quick responses are much appreciated.
