10-09-2018, 05:05 PM | #1 |
Power valve
Hi, I'm wondering if there is a replacement power valve for a Holley EAC-9510 tea pot carb? I don't think the original is available anymore.
10-09-2018, 05:18 PM | #2 |
Re: Power valve
More than likely one is available. Now whether it will seal well is another matter. You might try to PM Charlie ny. He generally knows what is available or a way to make something work.
10-09-2018, 05:29 PM | #3 |
Re: Power valve
Try Daytona Parts, 386.427.7108
10-09-2018, 05:31 PM | #4 |
Re: Power valve
If your talking about the actual brass power valve that screws into the bottom of the bowl, The only place I've seen them is in some of the expensive rebuild kits online. They are not all the same. Come in different hole sizes. You need to know the size you are replacing (stamped on top). Some also have two holes instead of one.
If you give me the full carb number I can look in my Holley manual and tell you the size. EAC-9510 isn't the full number. Should be another dash and a letter at the end. I assume this is a '52-'53 Merc teapot two barrel carb. Sal |
10-09-2018, 06:28 PM | #5 |
Re: Power valve
power valves. Big difference of course in this Holley the valve is vacuum operated. I've got some in my stash........PM me the number. Charlie ny |
