01-17-2015, 03:32 PM | #1 |
amount of paint on 35 pickup
I'm sure there are answers to the question of how much paint you need on the Forum, but haven't found it yet. Could someone give me an idea of what amount of paint we should have mixed for a 35 Pickup. Doing the truck in Dearborn Blue with black fenders & running boards. Taken down to bare metal and also doing the engine compartment, interior of cab & body.
Will most likely use sgl stage urethane PPG/Ditzler. Thanks for any help you can provide. |
01-17-2015, 03:40 PM | #2 |
Re: amount of paint on 35 pickup
Depends on what system you are using, because a quart of paint may turn into two or three quarts of sprayable material.
I have a "gallon" of paint, which really only has three quarts in the can. By the time I add 1 quart of activator I will have a full gallon ready to spray. I would guess a quart for the cab, a quart for the bed and engine compartment. Probably 1 quart for the fenders, but maybe two. |
01-17-2015, 05:27 PM | #3 |
Im doing a 39; all parts inside and out. Using PPG ESSS single stage. I haven't started on the bed yet and have used about 2 gallons (mixed). I probably used an extra 2 quarts because I didn't like the way an early coat turned out.
Gordon
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes.. |
01-17-2015, 05:31 PM | #4 |
Hey Jake, put paint on with a roller, or a power puff. LOL Walt
01-17-2015, 06:48 PM | #5 |
Consider that you will need 4 coats. I would buy a gallon of color and a gallon of black. Consider this paint as it will save you $$$ http://www.tcpglobal.com/restoration...chsheet_au.pdf
I've used both ppg(1 car) and Restoration Shop(2 cars). IMHO the several hundred dollars difference in the cost of paint isn't justified. I've also use Southern Polyurethane primer to good effect. IMHO the at least $1,000+ for using all ppg isn't necessary. Good to hear you are considering single stage. I finally figured out the practical difference between it and base/clear. With single stage to fix a scratch you can simply dab on the paint, sand and buff. With base/clear you have to re-apply clear on the whole panel. |
01-17-2015, 07:41 PM | #6 |
01-17-2015, 07:51 PM | #7 |
Hi Everyone; Jakno, not paint related, but, oof, I love what you started with!
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
01-17-2015, 11:55 PM | #8 |
Follow Gordon's advice... He is already painting, I am still getting ready to paint.
I HOPE a gallon is enough. Painted a 65 Mustang with a gallon and had some leftover. This 36 pickup isn't too much different in size. My saving grace is I'm using a factory pack color so matching should not be hard, and I'm using white which blends easy, unlike a red or a metallic. |
01-18-2015, 08:50 AM | #9 |
01-18-2015, 09:13 AM | #10 |
I used a tri-coat on my coupe, this was the first car I ever painted, screwed up a lot! most every panel was sprayed 3 times from mistakes. It took every bit of 2 gallons.
I don't think you have to worry about modeling with single stage like I did, just runs. I would start with 1 gallon, and save the inside cab area for last.
Thank God this is only a hobby! |
01-18-2015, 09:50 AM | #11 |
All good advice guys. Now if I can get the paint people to get the Dearborn Blue color right we'll be styling
01-18-2015, 09:56 AM | #12 |
Hate to say it, but I love the way it looks just as is. I would fix it up mechanically and just drive it!
Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
01-18-2015, 09:59 AM | #13 |
It took 2 gallons of blue Mtk omni on my wifes pickup
Felix 40 |
01-18-2015, 02:03 PM | #14 |
I used about 3 1/2 gal. on my '39 pickup. I painted inside the cab, doors, door trim panels, inside and bottom of bed both sides of fenders, hood and grille as well as everything on the outside. I stayed with one color for everything and used catalyst in the Nason paint. Sprayead 3 coats on undersides and 4 coats on out side. Only the running boards were painted black.
01-18-2015, 08:02 PM | #15 |
Whatever you do, if you use more than one gallon of the same color paint, mix them both together before you do any painting. No two batches will match, even if mixed by machine. Don't ask me how I know. Also, tell them you want them to write the formula down just in case you have to have some more mixed in the future.
01-18-2015, 09:49 PM | #16 |
I would have a gallon and a half of straight paint before its mixed.
"Thrifty Sixty" Ford V8 for 1938 |
