Old 05-01-2021, 06:07 AM   #1
AnthonyG
AnthonyG's Avatar
Question ‘35 gas pedal rod?
On a ‘35 is there supposed to be a grommet or bushing around the gas pedal throttle rod where it goes thru the floor, see red circled in pic. Pic is of a wood floor board mine is metal with same hole I’m speaking of.
File Type: jpeg E7AF7AB5-95BB-4D21-84D8-39F803FC0FFE.jpeg (15.1 KB, 63 views)
Nomad
AnthonyG is offline   Reply With Quote
Old 05-01-2021, 11:41 AM   #2
VeryTangled
VeryTangled's Avatar
Default Re: ‘35 gas pedal rod?
I have seen a 2"x2" felt square with a hole punched in the center stapled to the top side of the wooden toeboard. Not sure if that's stock.
-Jeff H
Old 05-07-2021, 11:55 AM   #3
Als48
Maybe a bellows-type rubber piece, like a shifter boot would be correct. I know the 51-52 F1's had something like that.
Als48 is offline   Reply With Quote
Old 05-07-2021, 01:28 PM   #4
Ggmac
I dont know if its correct but it works , use a master cyl rubber boot . The truck ones are what I use
Old 05-07-2021, 08:17 PM   #5
Hitman
Model A’s send a leather type of material for this. You can find them in the A parts catalogs. I can’t imagine 35’s were much different.
Hitman is offline   Reply With Quote
Old 05-08-2021, 10:05 AM   #6
AnthonyG
AnthonyG's Avatar
Thx all! I was not that concerned with originality, just thought if easy to order one I would & couldn't find anything listed for the ‘35. I have some 1/8” thick leather I’ll cut & fit a piece.
Nomad
