Old 05-18-2017, 11:03 AM   #1
JOHN CT
JOHN CT's Avatar
Default Seat adjusting
I have a 31 tudor and the seats are in a fixed position. I figured I would ask the experts. Is there any way I can install any type of adjusting track under my seat? I only want to adjust it back about a inch. Then I want to adjust it back to the original position if I have to load things in and out.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 05-18-2017, 11:13 AM   #2
Big hammer
Default Re: Seat adjusting
What about turning the original ones around, thus moving the seat back. For a quick readjustment use a clevis pin and hair pin. The pins that go through the floor can be left a little loose. I purchased new sliders for my drivers side, but it's not very user friendly. Thanks
Also I think the seat adjustment is covered in the Ford Service manual :-)
Old 05-18-2017, 02:31 PM   #3
René W
René W's Avatar
I did put the drivers seat 4 inch backwarts in a fixed position.
Loading and unloading at the passenger side,at the drivers side the steeringwheel is in the way enyhow.
It is a pile of shit bit it's my pile of shit
René W is offline   Reply With Quote
Old 05-18-2017, 05:15 PM   #4
ed thibodeau
I used a seat mech. out of a junk Saturn, welding it to 1x1x1/8 angle and narrowing it and now have 5" of travel fore and aft. Bolted the mech to the original seat mounting holes in the floor so there is no change to the body.
ed thibodeau is offline   Reply With Quote
Old 05-19-2017, 12:26 AM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I used escort seats with the tracks. Very comfortable. I've seen angle iron with several holes drilled for different front to back positions. Get creative. Try researching the archives as well.
Old 05-19-2017, 11:00 AM   #6
Kahuna
Kahuna's Avatar
This may not be applicable to a Model A Tudor sedan, but worked well for me.
I have a 32 Tudor sedan with the original seats. The seating position seemed too low to me and I wanted the seats a bit higher. (I judge seat height by my left arm resting on the window trim. If that's comfortable, then I'm pretty happy).
My wife had a 1996 or 7 Jeep Cherokee. I did some measuring and found that the passenger seat adjusting mechanism (Passenger only, because all Jeeps, 4 wheel drive or not, have a different seat base for the driver) would fit just fine. I did have to make 4 small angle iron brackets.
When installed, these seat mechanisms raised the seats 2" in height and give almost 12"
of adjustment fore & aft.
Maybe this helps someone.
Jim
Kahuna is offline   Reply With Quote
Old 05-19-2017, 12:32 PM   #7
1931 flamingo
1931 flamingo's Avatar
Mine has a piece of angle iron with multiple holes for adj (the adj slide for the Deluxe seat was "missing") I'm back about 6" and then made uprights to raise seat about 3". VERY comfortable driving, plus easier in and out.
Paul in CT
Old 05-19-2017, 12:41 PM   #8
JOHN CT
JOHN CT's Avatar
Paul in CT
Thanks flamingo I think your idea would work. With the least amount of welding and fabrication. But if I use a pice of angle iron it would be in a fixed position,I wouldn't be able to push it forward. There's times I carry tents ,coolers, chairs and people so I lift the drivers seat up to.
31 Tudor
66 Bonneville
Old 05-19-2017, 04:06 PM   #9
1931 flamingo
I flip the passenger's seat to access the back seat........................
Paul in CT
