05-02-2016, 03:21 PM | #1 |
Starting noise
Hi all, today i started the A as normal, however a loud clunk and the engine did not seem to turn over as smoothly from then on, engine runs fine, no noise or leaks, runs well, and starts ok just seems slightly less powerful, (could just be my imagination) took it on a 20 mile run no problems.
it is still on 6vlt. Any ideas? Thank you in advance. |
05-02-2016, 03:27 PM | #2 |
Re: Starting noise
Do you start it with the advance lever all the way up?
05-02-2016, 04:16 PM | #3 |
Re: Starting noise
I start it with the lever down, I think it is on upside down as the light lever is at the top so yes I think its right..
05-02-2016, 04:23 PM | #4 |
Re: Starting noise
I don't see how it can be upside down...
05-02-2016, 04:25 PM | #5 |
Re: Starting noise
05-02-2016, 04:37 PM | #6 |
Re: Starting noise
05-02-2016, 04:53 PM | #7 |
Re: Starting noise
ok, so i need to start with the lever up, i will try that, would it have caused a clunk, or a bang?
05-02-2016, 04:59 PM | #8 |
Re: Starting noise
Yes. It very likely backfired against the starter drive and that is the noise you heard. Careful, this can cause severe damage.
The spark advance lever (left lever) should be all the way up when you start the engine. Lower the spark lever to advance the engine after it is running. Good Day! |
05-02-2016, 05:00 PM | #9 |
Re: Starting noise
It can cause the starter to kick back... Always start in the retard / up position,, then move it down some .. Read through this owners manual
http://www.motormayhem.net/wp-upload...ion-Manual.pdf |
05-02-2016, 05:01 PM | #10 |
Re: Starting noise
GREAT, thanks guys. (what damage could it cause, what should i check to make sure its not too late?) Thanks again.
05-02-2016, 05:06 PM | #11 |
Re: Starting noise
When I RAISE / RETARD my lever, the unit in the distributor (plate) goes towards the right side of the car.
Lowering the lever/ Advancing it moves/ rotates it towards left side of car. |
05-02-2016, 05:57 PM | #12 |
Re: Starting noise
UKWOODY,
Does your name mean you are in the UK? If so, is your car RHD? If so, it is entirely possible that the advance lever does work the other way around. On RHD cars, there is a bell crank mounted on a boss cast into the inlet manifold. If you connect the rods the wrong way 'round, advance is up and because one arm is longer than the other, you can't get full advance.
05-02-2016, 06:02 PM | #13 |
Re: Starting noise
Here is woodies car L/HD
05-02-2016, 07:19 PM | #14 |
Re: Starting noise
That's a nice looking woody.
05-02-2016, 09:12 PM | #15 |
Re: Starting noise
OK, In that case, what I said doesn't apply and what you guys said, does.
05-02-2016, 10:47 PM | #16 |
Re: Starting noise
I would pull the starter and check it for damage. The spring may have been bent from kickback or the shaft might be bent.
05-02-2016, 11:36 PM | #17 |
Re: Starting noise
Agree
'31 180A |
05-03-2016, 01:12 AM | #18 |
Re: Starting noise
Thank you one and all very much.
