Old 07-31-2019, 01:47 PM   #1
Cave
Cave's Avatar
Default A couple shade tree handy tips...
Rose is a late '31 so I use a 6v fuel shutoff, but it gets pretty warm so I JB'd four aluminum heatsinks to it, helps keep it cooler. (I had to buy a box of them, so I still have 24 sinks left - enough to do 6 more shutoffs. Will send 4 of them if anyone is interested. No charge. Find me at caveluther at verizon dot net.)
After refurbishing and repositioning the steering column I found the best setup for the timing rod left my throttle rod a little long so I cut it and found that it slides perfectly into spare fuel line. (Leftover line removed for the above mentioned cutoff ) Quick and simple... cut to length and JB into the scrap fuel line. Any load is always in compression so there is little chance of it pulling apart.
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Cave is offline   Reply With Quote
