Old 06-13-2020, 11:59 AM   #1
Austincarnut
Default 239 / 2gc idle issues
This is a long story about why this even happened but here's my dilema: I have a 239 mated to a mercomatic medium case trans w/ 2gc carburetor, mallory dual point. I cannot seem to get it to idle low enough and strong enough to handle transmission engagement. Could the torque converter stall speed / rotating mass be an issue? I figure with the difference of 16 cubic inches vs the merc's 255, It should be able to handle this.
Austincarnut is offline   Reply With Quote
Old 06-13-2020, 01:05 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 239 / 2gc idle issues
Believe the idle speed spec. for the automatic is 485 RPM.
Mine is happy with 500-550 RPM.
What is your idle RPM?
Engine displacement has nothing to do with it.
Old 06-13-2020, 01:28 PM   #3
Austincarnut
My way of thinking is that there is not enough mass / inertia to maintain idle speed properly. I cannot get my idle speed much below 700 or so. Are you running a mercomatic? what is your idle speed in gear? thank you for responding...
Old 06-13-2020, 01:36 PM   #4
cadillac512
cadillac512's Avatar
1. Are you running a stock cam? A performance cam will exaggerate this problem.
2. Is the timing set at approx 4 degrees at idle speed?
3. Does the engine try to die when put in gear or is it just too harsh a shift into gear?
4. Do the idle mixture screws have any effect when turned out or in?
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-13-2020, 01:43 PM   #5
51 MERC-CT
51 MERC-CT's Avatar
My Merc-O-Matic has the same idle speed in or out of gear.
Don't over think the mass/inertia thing, get the RPM down to the appox. 500 range then see what happens.
Old 06-13-2020, 01:44 PM   #6
Austincarnut
The mix screws will stall the engine, Where they are now, they are too fat. the cam is stock for the '53 ford sedan the engine came out of. the transmission is '51 merc. the 2gc was built for this in mind. maybe timing is a tad retarded @ 2* BTDC
Old 06-13-2020, 01:51 PM   #7
cadillac512
Ok. Something's not right in the tuning if a lower idle can't be achieved. Maybe a vacuum leak (although rich running doesn't point to that) or maybe an idle circuit problem in the Rochester. That carb should work fine. I'm running a small base 2GC on my Merc and it'll idle at 400 if I want.
How does your engine sound when trying to run lower than 700 rpm? May get a clue from that...
Terry
Old 06-13-2020, 02:43 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
You say you are running a 2gc.
If you are using a Merc. manifold to mount it that had a divorced choke.
There is a vacuum port/hole that has to be plugged where the old choke mounted.
Old 06-13-2020, 05:12 PM   #9
Ggmac
How much vacuum is it reading , is it steady ?
Ggmac is offline   Reply With Quote
Old 06-13-2020, 06:05 PM   #10
Ol' Ron
Ol' Ron's Avatar
The stock distributor won't work with the 2GC distributor.
Old 06-13-2020, 09:18 PM   #11
JSeery
JSeery's Avatar
Think he is using a Mallory Ron.
Old 06-13-2020, 09:43 PM   #12
Ol' Ron
Ol' Ron's Avatar
Yea, I read that after I posted. Stupid factor vrty hi today .
Old 06-14-2020, 10:06 AM   #13
Austincarnut
Ok, I have it worked out. I didn't mention the engine is a fresh rebuild. Ran it about 4 hrs and progressively lowered the idle, I believe the engine was built very tight and would not cooperate until it was bedded in. It will now idle correctly. Thank you all for your help.
