10-31-2011, 10:18 PM | #1 |
Uuniversal Joint Lube.
For those of you who's Fords still use the torque tube and enclosed universal joint, is there a special lubrication you use to lube the joint itself? Thanks.
10-31-2011, 10:49 PM | #2 |
Re: Uuniversal Joint Lube.
11-01-2011, 06:58 AM | #3 |
I used John Deere cornhead grease & removed speedometer gear & worked very well. (I learned this from the Barners) Thank you.
Gary. |
11-01-2011, 08:30 AM | #4 |
Many deeply rooted opinions on this subject - do a forum search & you will see . I personally use straight 140 in the steering , tranny , u-joint cavity & the rear end . Dunno what year you're working on but on 33-34 's just pour four ounces in through the speedo hole & make sure your tranny stays full . The rear bearing in your tranny lets enough by to make up for the little bit lost through the wiping of the bell cork - felt - o-ring that you are using . If going this way the driveshaft seal & the gaskets on the bell are important . The # 1 cause of leaks using fluid here is overfilling . This is assuming the seal & gaskets are doing the job . Take a good look at how this stuff is & you will see that you only need 4 ounces in there . Many use cornhead grease with good results but that is a urea based product . The 00 viscosity slime { it pours sorta } that Ed Solari talked about is available for $7.99 @ qt at your John Deere dealer . Farm oyl instead of chevron but you don't need to buy 5 gallons and it is lithium based . From what I've been able to find out about " cylinder oil - soda soap grease " this stuff is in the ball park on the slime-o-meter . Your call on this but the packed in chassis grease thing has been known to destroy all . All meaning the u-joint , driveshaft & bearing and the speedo gear stuff . Seen this with me own 2 eyes . The thick chassis grease was all stuck to the outside wall and the stuff that needed lube was starved and you know the end result .
11-01-2011, 01:16 PM | #5 |
