Old 12-12-2019, 10:01 AM   #1
lotsagas4u
Default 1933 radiator bolt question?
Hello, I am replacing fender bolts and welting on my 33 coupe, my next question is, how much do you tighten the radiator spring bolts? They have a little pad that goes under the radiator, above the splash shield, then the springs, and a castle nut. Do you finger tighten until castle nut will fit cotter pin holes? OR???????
Thanks for the reply.
lotsagas4u is offline   Reply With Quote
Old 12-12-2019, 10:58 AM   #2
whizzernick
whizzernick's Avatar
Default Re: 1933 radiator bolt question?
yes
whizzernick is offline   Reply With Quote
Old 12-12-2019, 11:01 AM   #3
David J
David J's Avatar
If the pads are new and the bolts are fine thread [ as they should be ] I go with 3 turns past contact .
Pads will settle some .
David J is offline   Reply With Quote
