Old 01-27-2022, 03:19 PM   #1
TGJ
Default 1937 Ford Differential Gearing
My 1936 coupe is set on a 1937 chassis with 1937 transmission and differential. When I purchased the rolling chassis I was told that it might have been under a pick up truck. The gearing seems rather low. Would a truck differential have had a lower gear ratio than a car? On re-build the trans seemed "normal". Thanks for any insight.
TGJ is offline   Reply With Quote
Old 01-27-2022, 03:42 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1937 Ford Differential Gearing
Not necessarily, especially if the CAR was destined for a dealer in hilly or mountainous country. Any ratio was possible in either car OR pick-up.
You can almost positively tell whether your chassis was under a car or a truck by the presence of, or by the lack of the two box-like items riveted onto each side rail noticed just in front of the rear tire in the picture BELOW. PASSENGER CARS had those boxes riveted to the frame rails on '35-'40 CARS.
'35-'40 PICK-UP TRUCKS did NOT have those two appendages on their frame rails, as in the picture BELOW! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-27-2022, 07:39 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
stock 36 would be 4;11 ,from the service bulletins 37 --3:78 unless it was 60 hp then 4;44, as a option a 60 could have a 4:55 and the 85 could have 4:11 or 3:54
if it is a 37 it would have cable mechanical brakes
Old 01-29-2022, 03:37 PM   #4
TGJ
Thank you. That is very helpful. Yes, my frame has the boxes.
Old 01-29-2022, 03:41 PM   #5
TGJ
Thank you for the gear ratio info.
Old 01-29-2022, 04:56 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
So, it was originally under a PASSENGER car body. DD
T5 W/TORQUE TUBE
