05-17-2018, 07:40 AM | #1 |
spark wires
Can anyone post a picture of neat plug wires. I am trying to clean up a friends spark wires. They currently rub on the pulley. Thanks
John |
05-17-2018, 08:54 AM | #2 |
Re: spark wires
Found this pic on the Internet, a quick way with tywraps.
05-17-2018, 10:23 AM | #3 |
Re: spark wires problem fixed
I found that the owner had mounted the looms too far back. Moved then to the next set of manifold bolts and that did the trick
Before and After |
05-17-2018, 12:00 PM | #4 |
Re: spark wires
I put 90 degree terminals and boots on the distributor ends of the plug wires.
05-17-2018, 01:08 PM | #5 |
Re: spark wires
This is 59A I did about 20 years ago (the blue one). It's not super nice, but...
I was planning on using simple wire looms. I forgot why I didn't. I like the way the looms look. I found the red flathead picture online. |
05-17-2018, 01:19 PM | #6 |
Re: spark wires
05-17-2018, 01:32 PM | #7 |
Re: spark wires
You are missing the metal guide tubes and rubber guides on the distributor.
05-17-2018, 03:02 PM | #8 |
Re: spark wires
Maybe I'm missing something but I have never seen "metal guide tubes and rubber guides" on a crab style distributor.
08-31-2018, 10:15 PM | #9 |
Re: spark wires
On my woodie I have right angle ends on both the distributor and the spark plugs. I am hoping to find this combination in the morning at Napa. I like how they send the wires away from the pulleys and clean things up. I currently have straight ends on both ends of the problem pickup I'm working on. It's nice to have the 'search' feature here. Thanks.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
09-01-2018, 10:27 AM | #10 |
It also appears he has incorrect looms. 1942 looms had a crossover between the left and right conduits.
09-02-2018, 07:57 PM | #11 |
09-02-2018, 08:21 PM | #12 |
A correct firing order. But you could reroute at the crab. Fancy stuff. |
09-03-2018, 07:52 AM | #13 |
With the proper cross over tube in place, the wires that crossed the intake were enclosed / protected.
