Old 01-09-2012, 01:26 PM   #1
Maclab58
Maclab58's Avatar
Default Cowl light wiring
What is the easiest way to fish the wires for my cowl lights through where the cowl meets the frame? So far no luck.
Maclab58 is offline   Reply With Quote
Old 01-09-2012, 01:50 PM   #2
Doug in NJ
Doug in NJ's Avatar
Default Re: Cowl light wiring
A coat hanger! On a S/W body at least, it is not difficult.
Are you going between the cowl sheet metal and the 45-degree floor ail that supports the frontmost floorboard?
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 01-09-2012, 03:12 PM   #3
V4F
V4F's Avatar
steering column ................... steve
V4f
V4F is offline   Reply With Quote
Old 01-10-2012, 08:34 AM   #4
jw hash
jw hash's Avatar
run the wire behind your kick panel on the left side there is a big hole next to your toe board and it will come out next to your clutch pedal
jw hash is offline   Reply With Quote
