01-14-2020, 09:33 AM | #21 | |
Re: Oil pump p/up to pan clearance
Hell, the BESTEST way to look "cool" with one (or even two) yet have it (them) NOT leak or blow oil out is to drill and mount vent to the pan, WITHOUT cutting the big hole for the "breathing". ALMOST as bad as puttin' a sock in your pants, though. DD |
01-14-2020, 09:43 AM | #22 |
01-14-2020, 11:11 AM | #23 |
I just have to ask . . . how would YOU know about that little trick?
01-14-2020, 11:31 AM | #24 | |
You must mean the "fake vent" trick, right? If you must know, I always went to school barefoot 'cuz my family was so poor that we sure couldn't afford shoes or SOCKS for us kids! DD |
01-14-2020, 02:09 PM | #25 |
And all this time I thought the 'Sock Monster' only stole socks out of my dryer . . . who knew! LOL
01-14-2020, 02:32 PM | #26 |
01-14-2020, 02:51 PM | #27 |
Put the pan on without the gasket. Strike the bottom of the pan to adjust pickup. Now put the gasket in. Perfect clearance.
01-14-2020, 02:55 PM | #28 |
Wow amazing accuracy just wondering should the hammer be small or really large?
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-14-2020, 03:48 PM | #29 |
A compressed gasket is, what .040" thick? That oughta be plenty.
01-14-2020, 04:08 PM | #30 |
And when you crack the typical braze weld from the pickup tube to the oil-pump bolt flange - then the pickup falls off and you buy a new engine . . . yippee!
01-18-2020, 11:15 AM | #31 |
Here is photo of a breather installation from Vern Tardel's book. The Offy breather has a baffle inside the oil pan. Good to hear from Ron that when used in stock car racing they had no problems with the breaher. Could be the engine in the oil mist example had some blow by.
