Old 08-31-2022, 04:35 PM   #1
alexiskai
alexiskai's Avatar
Default Fabricating control rods?
Anyone have success fabricating replacements for OEM control rods (spark and throttle linkage rods)? I've been looking at options for buying ball joint linkages, plus rods, and then cutting/tapping the rods to thread the linkages onto. The problem so far is I can't find anyone who makes ball joint sockets for balls as tiny as the ones on the Model A.
Old 08-31-2022, 04:40 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Fabricating control rods?
I realize I already asked about this last year, but I'm asking again because all the proposed solutions involved buying rods for other applications that are too long, and then cutting/welding them to the right length. That's one way but I'm still interested in the possibility of fabricating them without welding.
Old 08-31-2022, 10:05 PM   #3
marc silva
marc silva's Avatar
Can’t you buy new ones and take them apart and shorten them? I am assuming here that you need shorter not longer. Just wondering as I have never had to mess with control rods but they put them together so I would think that I could figure out how to take them apart and make my own. Marc
marc silva is offline   Reply With Quote
Old 09-01-2022, 04:54 PM   #4
rotorwrench
rotorwrench's Avatar
The new ones I've seen use aluminum for the ball shroud where the old one were steel. I've had to open the hole up a bit more to get the new ones to fit on the ball. I've welded a few old ones but it is a PITA. Brass bushings with set screws are available so a person can cut them and the put the shortened rod pieces in the bushing and then tighten the set screws.
I've seen some pretty creative farmer fixes on these where folks bend a long one into a pretzel to get it to work for a shorter application.
For those interested here in a link to the sleeve:
https://www.snydersantiqueauto.com/p...9546&cat=41663
Old 09-01-2022, 04:58 PM   #5
alexiskai
alexiskai's Avatar
Link?
Old 09-01-2022, 05:27 PM   #6
Oldgearz
Originally Posted by alexiskai View Post
Link?
Google "rigid set screw couplers" and look on amazon.
Oldgearz is offline   Reply With Quote
Old 09-01-2022, 05:30 PM   #7
alexiskai
alexiskai's Avatar
Ah, right, I mistakenly read this as a solution for the ball sockets. OK, so we still do not have a way to do those sockets as an end-user.
