Old 05-10-2019, 11:15 AM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default Fan Bolt won't stay tight 1927
On my 27 I can't keep my fan belt tight.Should there be a lock washer before the nut? There not one on mine. What the problem?
Old Redneck is offline   Reply With Quote
Old 05-10-2019, 06:52 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Fan Bolt won't stay tight 1927
Use a lock washer and some blue LOCTITE and it won't loosen.
J Franklin is online now   Reply With Quote
Old 05-11-2019, 08:09 AM   #3
rotorwrench
rotorwrench's Avatar
New belts stretch for a bit till they break in plus they wear also. Previous advice will work to keep the bolt tight if that's the problem. They only need to be tight enough to do the job without slippage.
The fan bearing may also need service if it is getting any resistance to turning.
Another problem can be excessive wear on the pulleys or bad alignment, they both should have a bit of a crown to them. I assume this is the eccentric type fan belt adjuster that fits to the coolant outlet casting.
