Old 05-21-2022, 01:57 PM   #1
Marv 49
Default How does this clip go back on?
Putting the pedal assembly back together on grandpas Merc and it seems to me there is probably a trick to putting this clip back on. It doesn’t have ears like a regular snap ring, but was going to try snap ring pliers when I get back home. Thanks fellas if you have the answer.
File Type: jpeg 3F1ABFF4-47F6-4F46-B6F3-ACEB959C69DF.jpeg (75.3 KB, 399 views)
Marv 49 is offline   Reply With Quote
Old 05-21-2022, 02:02 PM   #2
petehoovie
petehoovie's Avatar
Default Re: How does this clip go back on?
Old 05-21-2022, 02:03 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Start with one end of the ring into the groove then work the rest of it in.
Old 05-21-2022, 02:36 PM   #4
Kube
Kube's Avatar
That clip isn't made of spring steel so working it over the end of the shaft will stretch it.
I have found the best way to install this clip is to place it on the end of the shaft and with a socket of just the correct diameter, hammer it down.
Still, you may need to compress it a bit once in place.
Old 05-21-2022, 02:39 PM   #5
woodiewagon46
They do make "C' clip pliers, but for one clip I wouldn't spend the money. 51 Merc has the answer.
woodiewagon46 is offline   Reply With Quote
Old 05-21-2022, 07:42 PM   #6
Blastfromthepast
Place one open end in the grove and work it on moving clockwise or counter clockwise.
Depending on which open end side you put in the grove. Don’t put both open ends in the grove at the same time and push it in the grove ,it will snap the clip.
Blastfromthepast is offline   Reply With Quote
Old 05-22-2022, 10:18 AM   #7
swedishsteel
Same method as putting a tire on a rim.
swedishsteel is offline   Reply With Quote
Old 05-23-2022, 06:20 AM   #8
aussie merc
aussie merc's Avatar
you need C clip pliers look and behave like circlip pliers but have flat ends any transmission mechanic will have them and be able to tell you where to get then should be available on line or any decent tool store
aussie merc is offline   Reply With Quote
Old 05-23-2022, 03:12 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
I drill a small hole on each end of the ring and use snap ring pliers to put those clips on or take them off. Works well every time....especially when you may need to take them off again
John
Old 05-23-2022, 03:52 PM   #10
34PKUP
34PKUP's Avatar
As stated just like mounting a tire on a wheel, no wasting time drilling.
34PKUP is offline   Reply With Quote
