Old 04-05-2022, 09:56 AM   #1
RalphM
RalphM's Avatar
Default One piece Front crank seal
Getting ready to put the one piece speedway seal on a 29 a engine. Can’t remember if it requires a sleeve on the front pulley. When I did the 52 Mercury engine I thought I remember changing the spiral sleeve out for something different.
But the earlier motor has the spiral sleeve built into the crank pulley. Will it leak if assembled with the spiral groove?
May be a speedy sleeve needs to be installed?
Thanks,
Ralph
RalphM is offline   Reply With Quote
Old 04-05-2022, 10:12 AM   #2
RKS.PA
RKS.PA's Avatar
Default Re: One piece Front crank seal
Ralph, have always used the speedy sleeve to cover up the groves in the front pulley. Seem to remember somewhere that the one-piece seal needs that vs. the original rope seal. Good luck!!
RKS.PA is offline   Reply With Quote
Old 04-05-2022, 11:51 AM   #3
Ken/Alabama
Ken/Alabama's Avatar
I never had an issue with the rope seal. Just saying.
Ken/Alabama is offline   Reply With Quote
Old 04-05-2022, 01:46 PM   #4
RalphM
RalphM's Avatar
You wouldn’t happen to have a part number for that speedy sleeve would you?
Old 04-05-2022, 01:55 PM   #5
flatjack9
flatjack9's Avatar
If the seal surface does not have a groove worn in it, the spiral is not a problem.
Old 04-05-2022, 02:37 PM   #6
Ol' Ron
Ol' Ron's Avatar
I've always used the stock sleeve if it;s in good condition. never had a problem..
Gramps
Old 04-05-2022, 04:14 PM   #7
RalphM
RalphM's Avatar
Sounds like it will work as is. Thank you all!
Old 04-07-2022, 08:23 PM   #8
alchemy
alchemy's Avatar
It is on mine. Mine has leaked like a sieve since day one. Someday when I get more time I'm digging the lip seal out and installing a rope seal like I should have done in the first place.
At least the underside of my sedan won't rust right now.
alchemy is offline   Reply With Quote
Old 04-07-2022, 09:03 PM   #9
tubman
tubman's Avatar
I'm with "alchemy". When I did my last engine, I ordered a one piece seal from Speedway. When I read the installation instructions (which called for filling the seal cavity with a bunch of RTV), I realized that the one piece seal was just an application of a close part in an application that it wasn't intended for. Use the rope seals, but follow the instructions to the letter.
Old 04-08-2022, 01:11 PM   #10
flatjack9
flatjack9's Avatar
Never had one that leaked.
Old 04-08-2022, 04:20 PM   #11
flatjack9
flatjack9's Avatar
I do not use the Speedway seal and use only a thin smear around the perimeter. Probably don't even need that. Just a precaution.
