07-30-2020, 05:27 PM | #1 |
292 oil pump
I think the oil pump is leaking. can I replace gaskets, O ring as easy as it looks in the shop manual ? thanks John
07-30-2020, 05:38 PM | #2 |
Re: 292 oil pump
The two gears will fall out, and maybe the drive shaft too.
07-30-2020, 06:25 PM | #3 |
Re: 292 oil pump
they will if your not careful.just work them back in if they do.
07-30-2020, 10:44 PM | #4 |
Re: 292 oil pump
I changed my oil pump O ring in the winter. I took some soft copper wire and looped it around the pump and when I removed the bottom plate I secured the pump gears in place. Set the O ring in place and loosed the wire enough to slide the bottom plate in place
07-31-2020, 10:54 AM | #5 |
Re: 292 oil pump
Thank you all try it soon.
07-31-2020, 06:20 PM | #6 |
Re: 292 oil pump
