04-26-2016, 12:11 PM | #1 |
1932 Ford firewall differences
I've done some research but everyone says that all 32 firewalls are the same. My friend has two that are different. These are not them but I found pictures online and circled them in red to show the two differences. Can someone in the know fill us in?
04-26-2016, 12:17 PM | #2 |
Re: 1932 Ford firewall differences
For one thing the second pic looks like the lower half has been sectioned in. the bead roll on the right looks to not match the section.
Tommy |
04-26-2016, 12:20 PM | #3 |
Well that may be, but the question remains. The two red circles highlight the main differences I am inquiring about. Again these are not our firewalls pictured, but we have one of each style. One has an extra bead and the other has an extra dimple.
04-26-2016, 12:31 PM | #4 |
Several different styles where used through out the year. Get David Rehor's book the 1932 Ford Book. The first firewall you have is a very early (and rare) pre May firewall. The indent was removed for more foot room. I believe without looking there are at least 8 different versions of the firewall thru the year.
04-26-2016, 12:33 PM | #5 |
Left one has the little dent that looks like a good place to park an oil can...that is an earlier one, set up for the power assist system that almost made it into production. The other later is pushed out in that area for more toe room. Both are normal.
04-26-2016, 12:34 PM | #6 |
All this from what I have read somewhere, I'm not an expert. Mart. Edit: Typing at the same time as Bruce. |
04-26-2016, 12:50 PM | #7 |
Mart,
Actually the late fire wall continues to provide for the never-released vacuum tank. That's why the upper red-circled clinch nut in the first photo ended up higher in the second photo. The bottom of the tank rested on top of the protrusion to increase the toe room in front of the clutch pedal which retains a slight indentation above it to center the tank. There were twelve different versions that I can think of but eight of those have only minor variations. |
04-26-2016, 01:03 PM | #8 | |
Charlie Stephens |
04-26-2016, 01:15 PM | #9 |
There is a pretty good look at the power assist system, or at least a version of it, in a Ford patent...I think I once posted the number here.
Things I can think of that made it into the world: That dent in firewall and the empty screw insert that all the firewalls have...the big (3/8 pipe, I think) vac port in early B intake manifolds...bellhousing clutch levers with an extra hole for the assist have turned up... I think darn near EVERYTHING on '32's came in multiple versions, mostly not documented in the parts books. The wonderful '32 restoration book is filled with examples, and I'm sure more will continue to appear. |
04-26-2016, 01:46 PM | #10 |
Bruce,
You're right, while I've never filled out a score card, the number of parts that were changed at least once or where there were variations due to different suppliers' manufacturing capabilities probably way outnumber those that remained unchanged from the beginning to the end of the model year. The number of parts unchanged in the engine compartment, for example, could likely be counted out on your fingers. |
04-26-2016, 04:48 PM | #11 | |
Another thing that made it into production was the large boss on the front drivers side of early Model B engines designed to mount the unit. Charlie Stephens |
04-26-2016, 05:36 PM | #12 |
Like so.
04-26-2016, 10:39 PM | #13 |
Well there you go, our early 32 with the early cowl vent etc has most likely had a later firewall fitted. "That's never happened before"
Interesting info. |
04-26-2016, 10:58 PM | #14 |
my4dv8- If your car was built outside the USA then a lot of interesting things may be in the assembly.
04-27-2016, 08:04 AM | #15 |
Very interesting stuff . . . kind of wild that Ford was attempting to make the clutch engagement all that much easier . . . never seemed like a problem to me. I guess they were busy working on "Power Clutches" . . . long before we all got used to "Power Brakes". Fascinating . . .
04-27-2016, 09:26 AM | #16 |
Look closely at the back end of the transmission and you'll likely conclude what's attached there also did not make it into production.
04-27-2016, 12:59 PM | #17 |
My older bro has a pretty much unmolested Tudor with an early vent, early front crossmember, early hood hood sides, early hood hooks, but a later firewall. I highly doubt his firewall was switched out. So there is no telling when all these changes exactly occured.
04-27-2016, 01:56 PM | #18 |
Because of Ford's formal engineering release process, we have a pretty good idea when a change was made to an individual part, but when that part ended up being used in a vehicle depended on a number of important variables such as existing inventories of the previously-used part (when they did not immediately stop using a particular version as was the case in a few instances), when a particular assembly plant launched production at the beginning of the model year (it was more than two months before the last U.S. assembly plant started up at the beginning of the '32 model year), and the distance between the origin of a part and its assembly plant destination. As a result, Corn Fed's example is completely believable.
05-04-2016, 11:45 AM | #19 |
I'm Corn Fed's brother. My tudor is #180 produced at the Des Moines plant. SN something in the 50,000's for a 4 cylinder. I always guessed the reason for the later firewall on a car with so much other early stuff is that the train car originally loaded with firewalls destined for Des Moines from Detroit got hijacked. Henry had to send another shipment, and by then they were producing the later firewalls.
The car also has early brake/clutch pedals, dashboard, visors, and probably many other parts I don't know about. |
