12-14-2010, 12:00 PM | #1 |
Holley 94 - Thread on fuel inlet
Can someone tell me what the thread is for the fuel inlet on a Holley 94 91-99 series? I believe it to be a 5/16", but cannot determine the thread pitch. I need a reducer to 1/4".
12-14-2010, 12:18 PM | #2 |
Re: Holley 94 - Thread on fuel inlet
Thread is 1/2x20 straight thread [NOT pipe thread].Original line is 1/4 OD and fittings are on the line are 1/2x20 compression ford fittings . A reducer is NOT nessory. I have the special ford fittings if you need them. ken ct.
12-14-2010, 03:12 PM | #3 |
A fuel filter can be placed there; Deutsch FF201 sold at AutoZone fit mine (later model than yours), but pretty sure it's still 5/16" for the hose. Why do you want to reduce?
12-14-2010, 03:27 PM | #4 |
Ken of Ct. is correct. This is a "special" Ford fitting and it is 1/4 inch tubing. You will drive yourself, and your local parts man nuts if you try to find one at your local parts store. Not many older guys left that remember. " Ford had a better idea."
12-16-2010, 08:37 AM | #5 |
www.dickshotrodcarbs.com |
