Old 10-05-2019, 07:38 PM   #1
30-9
Default Low end
Hi Gents
Took 39 out today. All stock. Highway no problem. Slow or low rpms car is not running smooth. Runs rough at idle. Moving slow it jerks unless I rpms are up.
Bubba Helmet distro built to 11A maybe 8k on it.
Where should I start to correct?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 10-05-2019, 10:04 PM   #2
drolston
drolston's Avatar
Default Re: Low end
Maybe float set too high, or debris in the float valve, or fuel pump pressure too high, causing minor flooding at low power. If you smell gasoline when things are getting jerky, that is a dead giveaway. Also look for wet gas around the top of carb.
Old 10-05-2019, 11:11 PM   #3
Brian
Brian's Avatar
Default Re: Low end
Blocked idle tube in carb
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 10-06-2019, 06:38 AM   #4
cadillac512
cadillac512's Avatar
Default Re: Low end
I agree with Brian-sounds like an idle circuit isn't delivering fuel properly. In addition,worth checking for a vacuum leak.
Terry
cadillac512 is offline   Reply With Quote
