03-06-2012, 06:44 PM | #1 |
leading question
i have most of the bodywork done on my 34 and am planning on using lead for some of the areas. my question is i need to build up the beltline and i want something straight to build the lead up against. can i use a piece of copper? i am assuming the lead wont stick to it. or should i use something else thanks tom
03-06-2012, 06:47 PM | #2 |
Re: leading question
Old timers would "build" it up on the metal. Or do you mean using the copper like a shelf?? Worked with an old timer that could do wonders with lead "once upon a time in a land far far away".
Paul in CT |
03-06-2012, 06:54 PM | #3 |
34,That will work. Use the copper as a shelf, then when you start filing make some tape lines along the beltline to guide as your filing.I leaded my wifes whole truck, hardly any filler. Ken
03-06-2012, 06:58 PM | #4 |
The lead will adhere to the copper if it is cleaned and tinned.
03-06-2012, 07:27 PM | #5 |
It sure will adhere. All of those Tiffany Studio lamps (and the thousands of knockoffs) are held together with soldered copper foil (wrapped around the edges of the glass). And then there is the more widespread example of how the various pieces of copper plumbing are held together.
03-06-2012, 10:57 PM | #6 |
www.fordcollector.com |
03-06-2012, 11:10 PM | #7 |
After you tin the area to be leaded the flux needs to be cleaned off completely or it will bubble up through the paint later. With the body filler products in use now there is little need for lead; except for bragging rights.
03-07-2012, 01:19 AM | #8 |
I wouldn't use copper as a guide you should be able to build up the Led wider than whats needed then file it back as well as using the file to create a aligned edge ,When you tin the job you stick some led to it then wipe the led over when its in it plastic state with a rag ,If you get a skin were the led is not stuck this can be a rust cavity .For a novas this could be difficult to do ,Another option is to use a filler as has been said ,You use a magnetic strip, or tape something on to guide you if the under side of the bead is straight use that ..Here are 3 shots of a card board spreader you can make ,One i used the other day as a guide I cut notches on each side to Aline a swag /Bead . you make it more square than whats needed then sand it into shape .This could be made in Aluminum as well this gives a nice straight line .
03-07-2012, 06:01 AM | #9 |
I used the Eastwood lead free solder on all my cars and it works geat and you can sand it with a sander along with the body files it cost a little more but the health issues make it ok
03-07-2012, 06:24 AM | #10 |
I meant to say that Eastwood has the flex tip to use just acelene instead of oxy and it gives the soft blue flame.worth it I started with the kit from them with the solder paste and flux,files and DVD
