03-06-2012, 10:36 AM | #1 |
Francis Stop Light Switch Fail
Just thought you might like to know that Ron Francis' low pressure brake light switch that's supposed to last much longer than the stock switch and cost three times as much lasted me two months. I'm running halogen bulbs for brake lights. It may be that the current was just too high for the switch. Interesting thing is that the switch failed stuck on instead of stuck off like the stock switches do when they fail. Maybe the contacts arced together because of the high current. I'm putting the stock one back in. At least I got a year out of them.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-29-2013 at 10:14 AM. |
03-06-2012, 10:41 AM | #2 |
Re: Francis Stop Light Switch Fail
A few years ago I installed one of the switches and it leaked. I was unable to stop the switch from leaking.
03-06-2012, 11:07 AM | #3 |
Halogen bulbs draw too much current for these switches. What I did was installed a horn relay on the frame rail close to the master cylinder so now it takes the load and all the switch on the master cylinder does is make and break the ground to operate the relay. Mine has been in service now for about 6 years.
03-06-2012, 11:13 AM | #4 |
Ditch the halogen tail lights. They draw too much current for the wiring in a Ford.
You can install flashlight reflectors behind the stock bulbs and get lights that are bright enough to see under all conditions, except having blue dots.
TomO |
03-06-2012, 11:38 AM | #5 |
Im using 32 Ford headlight bulbs in my taillights.
03-06-2012, 02:58 PM | #6 | ||
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
03-06-2012, 03:12 PM | #7 |
On my 35 PU I painted the insides of the tail light bodies gloss white. Put out Plenty of light. I have a Harley Davidson stop light switch on mine, silicone brake fluid.
