03-05-2012, 10:08 PM | #1 |
how to work dents out of hub caps?
I need to work some dents out of the stainless center caps for the 39 pickup. What is the best method and how should I go about this? Thanks for the input guys.
Seth |
03-05-2012, 10:51 PM | #2 |
Re: how to work dents out of hub caps?
I used wood, inside and out for the picking then did the filing.
Here's what I mean: Need large piece of wood about an inch thick such as plywood or just wide piece of pine. Cut various sizes of holes in it just larger than the various size dents. Then get wooden dowel various sizes and slightly "dome" the ends with sander or whatever. Cut them to usable length under 12 inches. Now locate the hubcap with a dent centered in a hole in the wood just larger than it and use an appropriate diameter of dowel and light hammer to gently tap on the dents to work them down into the space they are centered over. Will take some practice and experimentation with the various sizes of holes and dowels but with practice and patience and some skill you'll start getting it pretty close. This is essentially the first half of the "pick and file" method that also includes, after tapping the dents as close to perfect as you can, use a file on the surface to take the surface surrounding very small dents down slightly and identify the smaller dents needing additional tapping. Tap and file. Tap and file till it's smooth then sand with fine sandpaper to get scratches out and buff it on a buffing wheel with appropriate stainless abrasive and it can look pretty darn good. Good luck.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
03-06-2012, 12:39 AM | #3 |
The caps on my 40 Tonner were in rough shape. A local metal finishing shop took out the dents using a pick and a sandbag, then restored the stainless through progressive finishing with finer grits and machine buffing. They charged $50/each which seemed reasonable for the finished product (photos attached).
03-06-2012, 01:28 AM | #4 | |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 03-06-2012 at 01:34 AM. |
03-06-2012, 12:03 PM | #5 |
Another trick to use in taking dents out of stainless moldings/hub caps is to use a drill press to hold the dowel, etc.. Positioning the dowel/tool directly over the dent to be removed and using the power of the drill press in lieu of a hammer...
Bill.... 36 5 win cpe |
03-06-2012, 02:49 PM | #6 |
03-06-2012, 03:05 PM | #7 |
Bill, I removed the stainless just as you described. They poped off perfectly. Now I have the tedious process of pick and file.
03-06-2012, 03:44 PM | #8 |
Seth; I did my 39 caps. that is I took the stainless off as you did, then I sent the stainless out ....To Dave Turner, at 559-237-0892, I say this as Dave sent them back before I payed for them, and thay lookl great like new. Mr Turner is in Fresno, Ca. this was in 07. I hope he stikll there. he is retired and dose this to make a buck. Five of the caps are on the avador/ see em on my hubcap wall.lower left. and it was not cheep ?? he calls em "skins" ..... OLD....BILL
03-06-2012, 03:50 PM | #9 |
Or, you can call Bob Drake!
03-07-2012, 08:40 PM | #10 |
I use a tree stump ,cut in the middle fine the center an ues a wooden dowel round the end then have fun, it,s great to do it your self.Rick
