03-05-2012, 11:02 AM | #1 |
Bedding 36 windshield frame with urethane
I have a 36 woodie with the fixed windshield frame, cabrio also has the same frame.
I'm wondering whether I should have the glass shop install the frame with urethane like the new cars are installed or stick with the rubber gasket like original? Function trumps originality for me if it is better. |
03-05-2012, 02:11 PM | #2 |
Re: Bedding 36 windshield frame with urethane
urethane is hard to remove .If you are worried about leaks then a little silicone could work .
03-06-2012, 06:06 AM | #3 |
On my 36 coupe (with A/C) I opted out of the windshield opening. My glass shop used a 3M butyl adhesive rather than Urethane. They said " if you ever have to take it out you don't want urethane".
They said they could run a piano wire around it to get the windshield out. |
03-06-2012, 07:31 AM | #4 |
Gary. |
