Old 11-02-2015, 06:04 PM   #1
37 Coupe
37 Coupe's Avatar
Default Steering box rebuilder
Has anybody ever used the steering box rebuilder Lares that advertises in the Early Ford V8 Times? Friend of mine sent a '36 box to them that was quoted at less than $400 on phone but is now at almost $750.00. I have allways rebuilt my own a 37,39 and a 1946 but when I did them you could find NOS Genuine sector shaft and steering shaft,and even 20-30 years ago they were pretty expensive. I told him from the beginning I don't know how they could promise you the cheaper price. Also told him to go with later box to no avail.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 11-02-2015, 07:05 PM   #2
john worden
john worden's Avatar
Default Re: Steering box rebuilder
Yes, 37 Dodge PU recently. Looks good but haven't installed it yet.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 11-02-2015, 08:10 PM   #3
37 Coupe
37 Coupe's Avatar
Was that about the price range?
Old 11-02-2015, 08:22 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
I have two friends who used Lares to rebuild their '34 Ford steering boxes. They had a similar experience of "bait and switch" pricing, plus the rebuilds were not done well and gave them problems. Also have a friend who bought one of Hot Rod John's so called "EZ Steer" steering boxes for his '34 pickup. After two returns for correction of the same problem, he wound up sending it back a third time for a refund.
John
Old 11-02-2015, 11:40 PM   #5
fordor41
fordor41's Avatar
I had Lares rebuild my Saginaw steering box. Got it back with all the old parts, included in the shipping box, with the rebuilt gearbox. After a few months I had an issue. Sent it back and they remedied my problem. Unfortunately I was out shipping twice. Actually, I believe they give a lifetime warranty.
fordor41 is offline   Reply With Quote
Old 11-02-2015, 11:44 PM   #6
redmodelt
redmodelt's Avatar
RE EZ steer
Google "fordbarn EZ Steer"
Old 11-02-2015, 11:57 PM   #7
Bill S
What about Chris. I seen postings that he rebuilds steering boxes.
Bill S is offline   Reply With Quote
Old 11-02-2015, 11:59 PM   #8
Bill S
How about Chris. I seen some posts that he rebuilds steering boxes.
Old 11-03-2015, 09:55 AM   #9
Tim Brown
Tim Brown's Avatar
I have used NealinCA here on the fordbarn. He did an excellent job on my 34 box.
Tim Brown is offline   Reply With Quote
Old 11-03-2015, 10:06 AM   #10
jacob smith
jacob smith's Avatar
Mike Bartlett does steering box rebuilds. I have not had one done by him Yet. But he did ny 36 shocks for me and i am Happy
205 East E street
Kannapolis Nc 28083
704-728-2484
Ford
jacob smith is offline   Reply With Quote
Old 11-03-2015, 10:11 AM   #11
rotorwrench
rotorwrench's Avatar
I rebuild my own. I only had to make one tool for installing the worm gear on the steering shaft. If your worm & sector are good, it's just a matter of replacing the worn out stuff like gaskets, seals, bushings, and sometimes bearings. If the bearings are still good I reuse them.
Old 11-03-2015, 10:31 AM   #12
JT FORD
JT FORD's Avatar
I have read in the V-8 Times that the supply of NOS parts for shoeboxes is used up.
And that the China stuff varies from good to bad, some parts are OK and some are not. Would be a crap shoot whether the rebuild would be good or bad!
JT FORD is offline   Reply With Quote
Old 11-04-2015, 03:38 PM   #13
CT AV8
CT AV8's Avatar
Rotorwrench, I'd be interested in learning about that tool. I'm thinking about threading the shaft and pulling it through the worm with a grade 8 bolt and flat washer. Thanks.
CT AV8 is offline   Reply With Quote
Old 11-04-2015, 03:49 PM   #14
NealinCA
NealinCA's Avatar
Here is an old post showing how I press on/off worms. See post #6 in the following thread:
https://www.fordbarn.com/forum/showth...eal+press+worm
Neal
NealinCA is offline   Reply With Quote
Old 11-04-2015, 04:07 PM   #15
rotorwrench
Neal's got it. I just fabricated a steel tube that hugs the steering shaft and is anchored to keep it straight while pressing.
Old 11-04-2015, 04:31 PM   #16
CT AV8
CT AV8's Avatar
I got it. The pics are great. Thanks Neal, thanks Rotor.
Old 11-05-2015, 08:19 PM   #17
FlatheadTed
FlatheadTed's Avatar
Is it worth getting ,I am wonder ing is this common to both builders because they are using the re popped worms ,?? ( loose ) Ted
JM 35
3018]I have two friends who used Lares to rebuild their '34 Ford steering boxes. They had a similar experience of "bait and switch" pricing, plus the rebuilds were not done well and gave them problems. Also have a friend who bought one of Hot Rod John's so called "EZ Steer" steering boxes for his '34 pickup. After two returns for correction of the same problem, he wound up sending it back a third time for a refund.[/QUOTE]
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-05-2015, 08:30 PM   #18
38 Ford Guy
38 Ford Guy's Avatar
Lares rebuilt mine. It was $600 but they called me after they figured out what was wrong with an estimate. Had an issue first year they stood behind it. No complaints here.
"If you always do what you have always done then you will always get what you always got."
Henry Ford
38 Ford Guy is offline   Reply With Quote
Old 11-06-2015, 01:10 PM   #19
37 Coupe
37 Coupe's Avatar
I was trying to copy a post to this thread from Mikes Speed shop I think,he was giving a helpful response to my friends problem and Ryan or someone deleted before I got his contact information. Mayby private message me.
Old 11-06-2015, 01:40 PM   #20
37 Coupe
37 Coupe's Avatar
Got it,see it in the swap meet section.Thanks for all the responses and help.
