Old 03-06-2012, 04:06 PM   #21
mrtexas
mrtexas's Avatar
Default Re: e85 fuel
Originally Posted by joel View Post
Interesting article; check out natural gas price on the sign..2.54.
Natural gas @$2.54/MBtu is equivalent of $0.38/gal gasoline or crude at $16/bbl.
mrtexas is offline   Reply With Quote
Old 03-06-2012, 04:56 PM   #22
Mike51Merc
Mike51Merc's Avatar
Natural gas is a good motor fuel, but it has some refilling and safety issues because of the extreme pressures necessary to liquify it.
Some Police departments are using CNG, but they had to install blast shields in the trunk and reinforcement against rear impacts. One of those bottles lets loose and the poo poo hits the fan!
Mike51Merc is offline   Reply With Quote
Old 03-07-2012, 03:04 PM   #23
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Originally Posted by 46ford View Post
Isn't the solution to just not put E85 into your old Ford?
What am I missing?
YOU ARE MISSING NOTHING !!
We do ignitions but i also own Linder Fuel Injection www.lindertech.com and service fuel injectors each and every day and ship across the country.
Each day i get a set of injectors that smells like corn mash , when we question the customer ( often a repair shop) they say the customer tried to run E85 in a non flex fuel equipped vehicle.
To be flex fuel the vehicle has a ton of different parts from the stainless gas tank all the way to the fuel injector. Different programming on the PCM etc.
Less power , poor performance , harder starting all come with the E85 so you are 100% correct :
DONT PUT IT INTO YOUR VEHICLE !!!!!!!!
THERES NO RATIONAL REASON TO RUN THIS STUFF !!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-07-2012, 07:06 PM   #24
rotorwrench
rotorwrench's Avatar
Hopefully some brainiac will figure a way to turn primordial slime into a usable fuel like the mother earth did over a billion or so years of applying pressure and other factors to it. Then we just have to figure a way to produce lots of slime. We should be drinking the ethanol as long as our livers will hold out. I know when the gasoline is no longer available the alcohol will be all we have to keep us happy since it sure doesn't make a car happy.
