Old 04-15-2023, 11:29 AM   #1
imacrazy
Default Gas filter with the sediment bulb.
What are you fellows using as a gas filter with the sediment bulb
at the tank?
Thanks, Bill
imacrazy is offline   Reply With Quote
Old 04-15-2023, 05:27 PM   #2
marty in Ohio
marty in Ohio's Avatar
Default Re: Gas filter with the sediment bulb.
In my car I'm using a disposable filter that came from Snyder's. You got two in your order and they dropped into the glass bowl. I have the second one in now but I don't see them in their catalog any more. They have something that goes in the bowl now but is like 43 bucks. Don't know if it's worth it.
Marty
marty in Ohio is offline   Reply With Quote
Old 04-15-2023, 05:31 PM   #3
Gary WA
Gary WA's Avatar
at the tank?
Thanks, Bill
all stock! nothing added tried the filter in glass bulb fell apart after period of time. I use pencil filter in tank. thats my take on it!
www.whidbeymodelaclub.com
Old 04-15-2023, 06:18 PM   #4
GPierce
GPierce's Avatar
It’s a NAPA 3039 or WIX. 33039. All the same. Been using them for years in my A glass bowl.
File Type: jpeg B6A4F4FF-FE6F-4900-8A1F-FB2625B2210B.jpeg (16.9 KB, 17 views)
GPierce is offline   Reply With Quote
Old 04-15-2023, 07:14 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I just use stock screen, clean it every few years,mine is the cast iron one, I never touch the drain valve, the dirt goes to the outside not the center where the drain is
Old 04-16-2023, 08:07 PM   #6
MickyD
MickyD's Avatar
I use the glass bulb and pencil filter. So far so good. Double protection.
MickyD is offline   Reply With Quote
Old 04-16-2023, 08:19 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Old 04-16-2023, 10:37 PM   #8
ModelA29
ModelA29's Avatar
https://www.youtube.com/watch?v=vRn7Oulms4k
ModelA29 is offline   Reply With Quote
Old 04-17-2023, 07:01 AM   #9
imacrazy
Thanks fellows. the W ix 33039 sounds good.
Bill
Old 04-17-2023, 10:32 AM   #10
Jim/GA
Jim/GA's Avatar
Use the original fine brass screen that Henry called for (and the pencil filter).
Jim Cannon
"Have a Model A day!"
Old 04-17-2023, 04:12 PM   #11
ModelA29
ModelA29's Avatar
Still porous enough to let carb clogging crud through that has formed in the tank in the 90+ years that have gone by since Henry built it.
