10-13-2017, 11:45 PM | #1 |
Trying to open the light switch housing
I am trying to open the light switch housing, It went together easily a few months ago. Now I have got to turn but it won't open. Looking for ideas.
TIA
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
10-14-2017, 09:52 AM | #2 |
Re: Trying to open the light switch housing
Just pulls apart unless a bad short has welded it together, might be able to get a small screw driver to pry apart a bit, wet the joint with wd-40. That won't hurt the electrical parts and may loosen it a bit.
10-14-2017, 10:03 AM | #3 |
Same as above but in addition use a rubber jar opener to increase your grip.
10-14-2017, 01:56 PM | #4 |
As you try to turn it push it in this will help to disengage the "pegs" on the body as there is a "J" shape in the slots .
John in same place same weather . |
10-14-2017, 07:02 PM | #5 |
What a great idea. I ran to the kitchen knowing I had at least three of them in my collection. Sadly all mine fit Mason Jar lids and are too large to grip the switch housing.
10-15-2017, 12:26 AM | #6 |
10-15-2017, 01:33 AM | #7 |
Cut a couple 1" slices from an old bicycle inner tube to slip over the two halves, and you can get a good grip with no damage.
10-15-2017, 06:48 AM | #8 |
All the light wiring was missing from my 29. I bought one of Brattons high dollar US made housings. Would there be any harm coating the pieces with a little anti-seize compound to head off a problem like Chris is having?
10-15-2017, 07:24 AM | #9 |
I wouldn't hurt but this problem isn't common.
10-15-2017, 08:32 AM | #10 |
Go to the dollar store and pick up some rubber shelf liners.
I use them all the time to put under jacks, open /grip things, line the vice jaws. https://www.amazon.com/Tact-Premium-...W9YDT3AWTGDR0P |
10-15-2017, 02:15 PM | #11 |
I have a good grip on it. It simply won't budge.
10-15-2017, 03:17 PM | #12 |
Hi Chris,
WD-40 on the seam? Regards Bill |
10-16-2017, 12:35 AM | #13 |
Already soaked it with Kroil which is far better than WD 40.
10-16-2017, 01:22 AM | #14 |
Strap wrench for some leverage and remember "Righty-Tighty, Lefty-Loosey.
I Love Anything That Turns Money Into Noise |
10-16-2017, 04:04 AM | #15 |
Hi Chris,
Isnt it just a slight push in, then turn, or have you tried that?
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
10-21-2017, 07:43 PM | #16 |
I got it to turn. I just can't get it to separate.
10-21-2017, 07:47 PM | #17 |
Must have been made with that rare metal known as cantundoem. keep trying. Jeff
Let's let pylons, be pylons! |
10-22-2017, 07:06 PM | #18 |
Saw a movie, where a BIG Cook couldn't open a jar of Pickles. Handed it to a SKINNY Waitress & she WHIPPED it off! Maybe you need to take it down to your Coffee Shop--LOL
Pat would loosen a jar top, then hand it to me, as if she couldn't do it & LAFF!--GOD, I miss her! Bill Stupidass
10-22-2017, 07:37 PM | #19 |
I put a piece of pipe in the vice. Then stuck the pipe into the hole in the switch that the wiring goes through. A little leverage back and forth and it popped open. :-)
10-23-2017, 02:53 PM | #20 |
I know this is dangerous advice but would a tiny bit of heat on the female housing help?
