12-02-2012, 04:28 AM | #1 |
30 Roadster
Think I have an alignment problem or something is worn out in the front end of my roadster. At 35+ I have a little front end wobble, but at low speed I have a very noticeable wobble to the point of the steering wheel rocking back and forth.
What say thee? |
12-02-2012, 05:31 AM | #2 |
Re: 30 Roadster
All balls must be round and all connections tight, such as the pitman arm to sector shaft for a start.
12-02-2012, 08:01 AM | #3 |
Re: 30 Roadster
Alignment issues don't cause wobbles,, they cause 'pulls' and tire wear.. Incorrect toe setting can cause hunting/wandering..
For a wobble,, I would suspect a tire or wheel issue.. Have you checked the front end for 'tightness' ?? There shouldn't be any looseness from the wheel bearing thru the king-pins back to the tie-rod ends, drag link ends, pitman arm to steering/sector shaft, steering box mounting as well as steering box adjustment.. |
12-02-2012, 09:54 AM | #4 |
Re: 30 Roadster
What condition is the ball on the wishbone?? Is the wishbone ball mounting tight?? Start at the pitman arm and ck everything forward from that as others have stated.
Paul in CT |
12-02-2012, 12:38 PM | #5 |
Re: 30 Roadster
Ok thanks - I shall go over everything today or tomorrow and see if anything is loose.
12-02-2012, 01:00 PM | #6 |
Re: 30 Roadster
12-02-2012, 02:28 PM | #7 |
Re: 30 Roadster
12-02-2012, 04:42 PM | #8 |
Re: 30 Roadster
make sure the sector is not loose inside the pitman arm. move the steering wheel back and forth with the tires on the ground and ck
12-04-2012, 02:06 PM | #9 |
Re: 30 Roadster
12-04-2012, 02:08 PM | #10 |
Re: 30 Roadster
12-04-2012, 02:10 PM | #11 | |
Re: 30 Roadster
Opps messed up the quote box - as you saw in my previous reply the wheel swap did the trick - thanks |
12-04-2012, 02:30 PM | #12 |
Re: 30 Roadster
Glad it was something simple, all the other advice is worth looking into as well!... They were only tight once.....
12-04-2012, 02:59 PM | #13 |
Re: 30 Roadster
Yep, alot of good advice which I shall check. Just got back from a couple of mile cruise and much more plesant to drive. Thanks again everyone for the advice.. cheers
