06-09-2013, 01:41 PM | #1 |
51 ford carb.
The carb on my 51 the original type designed with the vaccuum port for the loadamatic dist.I blocked off the port because I am running a Bubbas chevy conversion which needs vaccuum from below the throttle plates.I feel the car should run better than it does and wonder if there is a better carb choice.Thanks Phil
06-09-2013, 03:04 PM | #2 |
Re: 51 ford carb.
find a 4 bolt Mercury intake, install and then run a Rochester 2G
06-09-2013, 03:52 PM | #3 |
Re: 51 ford carb.
Alan X 2.
Henry |
06-09-2013, 04:34 PM | #4 |
Re: 51 ford carb.
The 2GC works fine, specialy with a bigger engine like a 276 but your stock 239 should run good with the stock Holley. Walt
06-09-2013, 05:56 PM | #5 |
Re: 51 ford carb.
You might want to check the timing curve. Bubbas distributors are adjustable in both Mechanical and vacuum. Another old timers trick is to being the engine up to a fast idle and slowly bring you hand over the carb. If the engine begins to speed up you're lean. If it stalls out Rich and if it just slows down OK.. An AF meter is more accurate.
06-09-2013, 06:03 PM | #6 | |
Re: 51 ford carb.
06-09-2013, 06:53 PM | #7 |
Re: 51 ford carb.
I am running a 2gc rochester from a 66 v6 jeep and played around with the jets to get it running good, I too am running a chev dizzy from Bubba but with no vacuum advance-I wonder if I should change out to an adjustable vacuum advance. The engine is a 51 merc with a 77b Isky cam, currently running a 3:25 gears in a 9" ford, not really good for around town on hills but great running down the road!!
06-09-2013, 07:07 PM | #8 |
Re: 51 ford carb.
Phil,
Try setting the initial at 4 degrees....this is with the vac hose off the dist and the source of vac plugged. I'm talking shade tree stuff here.....crack the throttle while the timing light is seeing the mark on the pulley and the pointer...you should see the mark jump about an inch. The throttle cracking thing should be enough to get you to 2500 rpm. This is a rough and dirty way to determine that things are functioning. If Bubba set it...it's right. A properly set up 94 is all you'll ever need. A bolt on alternative would be a Stromberg 48 which Uncle Max can fast freight to you. The Stromberg carb eliminates the sometimes erasable vac power valve and is tuner friendly. Charlie ny |
07-07-2023, 07:55 PM | #9 | |
Re: 51 ford carb.
07-08-2023, 11:18 AM | #10 |
Re: 51 ford carb.
Holley 94 carbs can be fairly easily modified for ported manifold vacuum to the distributor, using the same port on the backside of the carb.
Saves a lot of time and money. Sal |
07-08-2023, 01:42 PM | #11 | |
Re: 51 ford carb.
Now THAT is valuable information! Terry
07-08-2023, 02:15 PM | #12 |
Re: 51 ford carb.
The Holey 94 cannot operate any load a matic distributor. The 94 used on the 8ba engines has a different vacuum sysem for this distributor. However any carb can run the converted SBC distributor as this is NOT ported vacuum, also do not use this port for the chevy distributor as this won't work either Hope yoy understand this. maybe soneone else can explain it better.
The old fart!!! |
