Old 12-02-2012, 04:28 AM   #1
William Kelchner
William Kelchner's Avatar
Default 30 Roadster
Think I have an alignment problem or something is worn out in the front end of my roadster. At 35+ I have a little front end wobble, but at low speed I have a very noticeable wobble to the point of the steering wheel rocking back and forth.
What say thee?
William Kelchner is offline   Reply With Quote
Old 12-02-2012, 05:31 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: 30 Roadster
All balls must be round and all connections tight, such as the pitman arm to sector shaft for a start.
Old 12-02-2012, 08:01 AM   #3
Patrick L.
Patrick L.'s Avatar
Alignment issues don't cause wobbles,, they cause 'pulls' and tire wear.. Incorrect toe setting can cause hunting/wandering..
For a wobble,, I would suspect a tire or wheel issue..
Have you checked the front end for 'tightness' ?? There shouldn't be any looseness from the wheel bearing thru the king-pins back to the tie-rod ends, drag link ends, pitman arm to steering/sector shaft, steering box mounting as well as steering box adjustment..
Old 12-02-2012, 09:54 AM   #4
1931 flamingo
1931 flamingo's Avatar
What condition is the ball on the wishbone?? Is the wishbone ball mounting tight?? Start at the pitman arm and ck everything forward from that as others have stated.
Paul in CT
Old 12-02-2012, 12:38 PM   #5
William Kelchner
Ok thanks - I shall go over everything today or tomorrow and see if anything is loose.
Old 12-02-2012, 01:00 PM   #6
grapp
Also, switch the rims from front to back and take it for a spin first and see if anything changes, you could have a bent rim...or a way out of balance rim/tire combo.
grapp is offline   Reply With Quote
Old 12-02-2012, 02:28 PM   #7
ora masters
whare in steering box can cause w obble at slow speeds also
ora masters is offline   Reply With Quote
Old 12-02-2012, 04:42 PM   #8
Mitch//pa
make sure the sector is not loose inside the pitman arm. move the steering wheel back and forth with the tires on the ground and ck
Old 12-04-2012, 02:06 PM   #9
William Kelchner
Switched the drivers side wheels and went for a drive. The wobble is almost gone. Looks like the driver side front wheel is out of whack.
Old 12-04-2012, 02:08 PM   #10
William Kelchner
Thats seemed to be the problem - I messed up the quote. Thanks
Old 12-04-2012, 02:10 PM   #11
William Kelchner
Opps messed up the quote box - as you saw in my previous reply the wheel swap did the trick - thanks
Old 12-04-2012, 02:30 PM   #12
grapp
Glad it was something simple, all the other advice is worth looking into as well!... They were only tight once.....
Old 12-04-2012, 02:59 PM   #13
William Kelchner
Yep, alot of good advice which I shall check. Just got back from a couple of mile cruise and much more plesant to drive. Thanks again everyone for the advice.. cheers
