10-31-2020, 02:48 PM | #1 |
A very unhappy gear
Further to my recent post about a frame crack, the pictured gear is why I pulled out the tranny. This is the reverse idler gear. I rebuilt the unit about 8,000 miles ago(old type pre-39 synchros gearset) with a new cluster gear, bearings, thrust washer, etc. but otherwise original gears, has worked perfectly with good shifting and no funny noises. Went to do a routine oil change and heard the "clink" of a couple of gear teeth in the pan. Surprisingly, everything else looked fine(cluster gear, low/reverse slider gear, etc) except for a disintegrating caged bearing at the front of the cluster gear.
Any ideas as to why this would happen-for now, I'm just chalking it up to "old age" of the reverse idler gear? I've always shifted it carefully into low and reverse and there's no wear on the low/reverse slider to indicate otherwise Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
10-31-2020, 03:07 PM | #2 |
Re: A very unhappy gear
Probably metal fatigue once a piece lets go it will take out the others in the caged area. You got lucky it didn't ruin the cluster gear etc. etc.. Go buy a Lottery ticket. JMHO
10-31-2020, 05:18 PM | #3 |
BTW, if you rebuilt it with "newly made" caged roller bearings, that may have been the issue. I do not know of any that are available that are correctly made - the "cages" are not anywhere near the quality of material and heat treat as Henry's originals. Take a fine file and see if you can file the edge of the cages - if you can, don't use them. Then take an original and do the same thing - you'll see what I'm talking about as far as hardness.
I only use good originals or NOS ones (if I can find them . . . hard to locate these days). Also, the reproduction cluster and reverse shafts are junk - poor materials, not correct heat treat and .001 to .0015 undersize. Folks buy them - thinking they're doing the right thing and yet they are very poorly made. Use original cluster/rear shafts . . . good used or if you're lucky enough - NOS ones (which I haven't seen in years). I actually made my own shafts for my 39 box in my 32 Cab. I used high-quality linear shafting material. |
10-31-2020, 06:39 PM | #4 |
Thanks for the advice, I didn't realize poor quality roller bearings were such an issue, but looking around at various posts (both here and on the model A forum as they use the same roller bearings) it seems a real problem. I got these from Mac Van Pelt when I did the rebuild and I will try to contact him next week to see what he says, since he's forgotten more about these transmissions than most people know. I will need to replace the cluster gear shaft as it was roughed up a little where the bearing went south but I will see if he has a decent used one. Looks like NOS or NORS roller bearings are rarer than hen's teeth
jimvette I gave up buying Lotto tickets many years ago, maybe I should start again (!) Adam
10-31-2020, 09:03 PM | #5 |
At some point in my earlier hot rod life I have broken every gear in the transmission, except the reverse idler. You should be proud!
10-31-2020, 10:14 PM | #6 |
"Came too close to dying to stop living now!" |
10-31-2020, 11:46 PM | #7 | |
Two of the best sources I've found for quality transmission parts are Mac Van Pelt and Michael Driskell, @ 3rd Gen Automotive.
11-01-2020, 08:16 AM | #8 |
JM, I don't suppose you have any more of those "good used originals" just lying around??
11-01-2020, 09:13 AM | #9 |
Adam, I'm sure I do have some....will take a look, and let you know via a pm. I've been doing a few conversions lately....putting the later '46-'48 transmission gear sets into '35-'36, pn 48-xxxx cases. Many of these '35-'36 gear sets I'm removing have low mileage, near perfect components
11-01-2020, 11:30 AM | #10 |
John, if you do that would be great, thank you
