Old 03-31-2017, 05:49 PM   #1
clo2jim
clo2jim's Avatar
Default Wire Clips locations
Does anyone have a diagram for a 1930 Town Sedan (Murray) showing where the wire clips are located along the frame and where clips should be located along the back (on the wood) if you have two tail lamps?
clo2jim is offline   Reply With Quote
Old 03-31-2017, 10:42 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Wire Clips locations
Let's see that the standards have to say;
"The rear lamp wiring was routed under the rear motor
mount to the bottom inside of the left rail and fastened
with a clip. It was then routed through the center cross
member with the transmission mounted stoplight switch
or under the cross member with the cross member
mounted switch, and along the bottom inside of the
lower left rail, fastened with three clips. The harness
was routed to the frame upper rear corner bracket where
it was fastened with a clip. Passenger vehicles with the
drum type rear lamp had two clips holding the wires to
the lamp support. Later models had the lamp extension
wires attached to the rear fender bracket or fender skirt
with a special clip. Beginning early 1929 a clip (A-
14592) was used to support the wiring to the bottom
of some wood framed bodies just rearward of the rear
cross member. The clip was attached to the left floor
sill with a #10 black enameled round head wood screw.
Applicable bodies included Fordors, Station Wagons,
Panel Deliveries, and 78-B pickups. All clips were black
enameled."
In 1930 the factory would not have wired an additional tail light so the method of fastening the the wire would have been up to the installer.
Sorry, but the uploading part of this site is down at this time to up load the different types of clips (page 2-16)
Old 04-01-2017, 11:16 AM   #3
Bob C
Page 586 of the Service Bulletins tells how to wire the extra tail light.
Bob
Old 04-01-2017, 11:42 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I place them wherever they provide the MOST protection from damage.
Bill Careful
"THE ASSISTANT GURU OF STUFF"
Old 04-01-2017, 12:32 PM   #5
clo2jim
clo2jim's Avatar
Thanks everyone for your answers - now back to the garage to see what I can do
I didn't look in the correct part of the Judging Standards where the answer was
Last edited by clo2jim; 04-01-2017 at 11:23 PM. Reason: Spelling anf additional comment
Old 04-01-2017, 12:39 PM   #6
Mitch//pa
If your frame is freshly finished be careful sliding them on. They will scratch it right down to the bare metal. I spread them with a snap ring pliers as i install them..
Old 04-01-2017, 11:26 PM   #7
clo2jim
clo2jim's Avatar
Thanks Mitch//pa for this information - I was only missing a couple and have to install correct ones for the tail lamp cross-over wire. I had 2 - need a couple more for the cross-over wire (Next parts order) Frame is not freshly painted (original car) so not an issue
