07-08-2010, 07:29 PM | #1 |
Another stuck Flathead story....
Another stuck Flathead story.... I traded for this flathead engine that "Supposedly" had been sitting dry in a garage for years.... "It's stuck, but can't be bad" that was the story. I've tried every old school trick in the book to get it free. Marvel Mystery, Kroil, PB Blaster, Coke, Pepsi, antifreeze, nothing worked. Won't budge! Here's what we found tonight. Beware! It's not pretty. Wonder why it was stuck? Sitting dry for years. Really? What they didn't tell me was, that it obviously sat under a drain spout for a few years before that. Either way, didn't see any cracks, and the cylinders don't look too bad believe it or not. It did move a little bit, so it's soaking again. Wish me luck! Later, Kevin Attached Thumbnails __________________ |
07-08-2010, 08:25 PM | #2 |
Re: Another stuck Flathead story....
Hey Kevin, here's wishing you luck! It already looks much better. Please keep us informed of your progress. Very encouraging that it has moved a lick. Dennis/Arkansas
07-08-2010, 08:31 PM | #3 |
one guy told me he put brake fluid in the cylinders and lit it on fire, he said that it burnt very slow
07-08-2010, 09:05 PM | #4 |
it looks like it cleaned up real good i got one on a engine stand and guy said it was no good i am going to get another opinion
07-08-2010, 09:55 PM | #5 |
Obviously all the "Remedies" to a stuck flathead worked on the gunk. It's still stuck though. In the valve guides as far as I can tell. Looks as though the bottom end is loose, but the valves are stuck.
Does that sound right? |
07-08-2010, 10:02 PM | #6 |
07-08-2010, 10:20 PM | #7 |
Those upper right two pics, is that just after tear down, or after you had something in the engine?
07-09-2010, 05:10 AM | #8 |
07-09-2010, 12:01 AM | #9 |
07-09-2010, 07:45 AM | #10 |
Here in Texas we have 55 gallon drums.
Ross Murphy 1939 Ford Standard Coupe |
07-09-2010, 09:00 AM | #11 |
When I bought my 39 Std. it had been sitting for several years like 15. The engine was stuck. When I got it home I took the spark plugs out and filled the cylinders with PB Blaster pent fluid. Then I put a new battery in and every time I walk by the car I would bump the starter. The third day the engine broke loose.I then drain the oil and it had water in the oil??? I then check the tourque and the right side was only 40 pounds. I put a new head gasket on that sside. Been driving the cat for two years with no problem.Just takes time to solve the problem.Might try a little heat since you have the heads off also.
07-09-2010, 09:09 AM | #12 |
07-09-2010, 09:14 AM | #13 |
Try acetone & atf 50-50 mix. it is the best penetrate. squirt valve guides and all often.
07-09-2010, 03:59 PM | #14 |
07-12-2010, 07:04 PM | #15 |
07-12-2010, 09:08 PM | #16 |
Used to restore old one-cylinder farm engines -- often stuck. You are doing the right things but you are trying to bust everything loose at once. Take out the crank and periodically smack each piston with a piece of wood and big hammer. Some will come loose sooner than others.
Douse the valves, guides and lifters with PB Blaster and tap each one with a soft hammer. Once something starts to move squirt it and tap it in and out. If it moves it's on the way out. The last engine I restored (check video below) had deep grooves in the cylinder and a lot of rust. I hit it with a hone and put it back together. "Clearance" meant something else in those days. The engine is 6 hp and weighs 1,860 pounds! Good luck. https://www.youtube.com/watch?v=fLB5BxO8GvA |
07-09-2010, 09:31 AM | #17 | |
There are 55 gallons in a drum and 42 gallons (1 U.S. gallon = 3.78541178 liters) in a barrel (i.e., 1 barrel = 158.9872948 liters). Originally there were 40 gallons to a barrel. However, that was changed in the mid-19th century to give a little extra so consumers wouldn't feel "cheated." A little over 23 gallons of gasoline can be refined from a barrel of oil. Other products (jet fuel, lubricants, etc.) make up the rest. The easy way to remember the number of gallons in a barrel of oil: There are 7 letters in gallons and 6 letters in barrel. 7X6=42 gallons. 42 US gallons.
Joe. |
07-09-2010, 10:25 AM | #18 |
07-09-2010, 12:04 PM | #19 |
I had a similar piston in my 8BA. I soaked it for days and took a BFH to it abd beat the living snot out of it until it came out.
07-09-2010, 12:11 PM | #20 |
Tilt the block so a deck is level. Degrease the bores as best as you can. Fill the bores with Phosphoric Acid. It will dissolve the rust. All the penetrants in the world will not dissolve rust.
