05-20-2017, 11:10 AM | #1 |
Pan gaskets with no holes for screws
First time putting a flat head together. The gasket set I bought has no holes for the pan screws. Has anyone used these gaskets before?
I'm thinking I can poke a hole through the gasket after they are bonded on the block and just let the pan screws work their way down through the gasket material when I screw them in. Will this work? Thanks
Nothing wrong with it except for the name on the front. Alex |
05-20-2017, 12:18 PM | #2 |
Re: Pan gaskets with no holes for screws
Alex, I wouldn't try it. All you need is a slight lump here and there to create a major mess on your garage floor. To do it right, you'd have more time and effort into it than it's worth.
Alan |
05-20-2017, 12:35 PM | #3 |
What brand of gaskets did you buy? It sounds like the pan gasket slipped thru the process without getting punched, I'd take it back.
'52 F-1, EAB flathead |
05-21-2017, 10:38 AM | #4 |
I've seen some cork that are punched , but you have to push the little circles out of the gasket to use it. Maybe?
05-21-2017, 10:48 AM | #5 |
on an unrelated event I am pulling the floor pan from my 42 for the third time. Last time I put new rubber down and just kinda halfassed the install. I also had to fight with the bolts because of it. This time I am taking the time to do it right, which would be a lot easier if I had taken the time to do it right last time. Just saying. Ed |
