Old 09-13-2019, 06:58 PM   #1
30-9
Default 39 radio antenna
Hi Gents
I have a stock antenna (on the roof) on my 39. I want to remove just the rod and leave the base, on the roof. I removed the (what I think is) set screw. However the rod will not pull out.
What’s the trick. I see no other screws. There is a spot on opposite side where another set screw may have been but it appears to be missing.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 09-14-2019, 09:58 AM   #2
marko39
Default Re: 39 radio antenna
It should come out with the set screws removed, probably held in by corrosion.
marko39 is offline   Reply With Quote
Old 09-14-2019, 10:07 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
I am pretty sure that the wire is clipped to the shaft in the middle
