05-17-2010, 05:31 AM | #1 |
Private Messages ????
In my private Messages it showes that I have 3 stored Messages.
I clicked onto List Messages but nothing came up. Also I know it says PRIVATE I assume only the person that I send it to should get it ( JUST INCASE I AM PLANNING A SUPRISE B-DAY PARTY ) Some day I may get it. THANKS GUYS for the understanding. |
05-17-2010, 05:46 AM | #2 | |
Re: Private Messages ????
How do I send Private Messages? Private messages work a little like email, but are limited to registered members of this forum. You may be able to include BB code, smilies and images in private messages that you send. You may send a private message to a member of this forum by clicking the 'Send A Private Message' link in the private messaging section of your user control panel (more info), or by clicking the 'Send a Private Message' link in the drop down menu that appears in a member's posts when you click on their username. When you send a message, you have the option to save a copy of it in your 'Sent Items' folder. How do I work with Private Message Folders? By default, you will have two folders in your private message area. These are the 'Inbox' and the 'Sent' Items folders. The 'Inbox' folder contains any new messages you receive. It allows you to view all the messages you have received, along with the name of the person who sent it, and the date and time it was sent. The 'Sent Items' folder contains a copy of any messages that you have sent, where you have specified that you wish to keep a copy for future reference. You can create additional folders for your messages by clicking the 'Edit Folders' link. Each folder has a set of message controls which allow you to select messages, then either move them to one of your custom folders, or delete them. Once you have selected your messages, you can choose the following options in the 'Selected Messages' box at the bottom of the list:
If you would like to keep a record of your messages before you delete them, you can use any of the 'Download as..' options listed above to take a copy and store them on your own computer. Whenever you read a message, you will have the option to reply or forward it to another member of the forum. You may also have the ability to forward that message to multiple members of your contact list. Hope this is some help. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell |
05-17-2010, 06:23 AM | #3 |
I am having a problem REPLYING to private messages. It seems like I receive 2 copies of each message. Is the recipient(me) supposed to fill in an answer below the second listing of the PM? Or should he start a completely new PM to reply to the first PM??
05-17-2010, 09:34 AM | #4 | |
The PM you are seeing first has a "reply" button right under it. If you hit that you will get a new window that opens and you can type your reply PM back to the sender then hit "Submit Mesage" OR Once you open up the PM that you just received and read, you'll see a "quick reply" box with the message in it again. You can reply in that box and then hit "submit message". Both work, ones just alittle quicker without as many options. If you reply in the "Quick reply" box but want the same options then just hit the "go advanced" button and you then get the same screen as if you replied regularly. If you, or anyone wants to practice PMing and replying, feel free to send me a PM and I will reply. Also, keep in mind that just because YOU are only sending it to one person doesn't mean that the person you sent the PM to won't "forward" the PM to someone else. Never say anything in a PM that is really private unless you really trust the person you are sending the message to.
Your Topless Cruzn Pal, Denise |
