Old 09-20-2013, 09:45 PM   #1
Ralph Moore
Ralph Moore's Avatar
Default Two questions
I know there was a thread recently about heads, but I can't seem to find it.
What are the markings 29A-LH and 29A-RH? Are these Mercury?
Second question, what size is the crank nut on a 59AB style block?
I can't see it well and I don't have a spare laying around to check.
I'm trying to free up an engine in a 47 Business Coupe, I am soaking with MMO, but it's been sitting since 1968, and I'm afraid I may have to pull the heads.
Ralph Moore is offline   Reply With Quote
Old 09-22-2013, 12:18 PM   #2
Ralph Moore
Default Re: Two questions
Anyone?
Old 09-22-2013, 11:20 PM   #3
G.M.
Ralph if you have a parts washer gun put the syphon tube in the MMO bottle and spray in the plug holes and down both sides of the cab with the plates open. I wouldn't force it to hard to turn over. If it's in the car after soaking a few days put it in gear and rock it back and forth. I have done lots of them and they all ran good. I don't recall the nut size it's about 1 1/8". G.M.
www.fordcollector.com
Old 09-23-2013, 08:52 AM   #4
Ralph Moore
Thanks, the engine is in the car and it's had the hood on it, but sadly it was parked outside for all those years. Air cleaner was off, and so was the breather which worries me more.
With the melting snow I hope none of it got in there. I will pull the pan soon and see what lurks below.
I'm considering just pulling the entire front clip, because it needs repainting(rest of the paint is pretty nice), and the frame is damaged( shocks pulled a section out) and it would make it easier to work on the motor.
Old 09-23-2013, 10:47 AM   #5
41ford1
41ford1's Avatar
Ralph,
This is an old thread on the 29 heads. https://www.fordbarn.com/forum/showthread.php?t=95964
There is a good discussion in it.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 09-23-2013, 01:45 PM   #6
OLD...BILL
OLD...BILL's Avatar
AIR PRESSURE and air pressure and more air pressure, a rubber tipped blow gun at each plug hole, it will do two things, one push that MMO to and even past the rings, and let it sock... The other thing it will do, is make the engine want to turn over.... Make up an air hose connector, using and old spark plug base,and your quick connector air hose, some will blow out the exhaust, some out the intake, AND some will be on comp. stroke, leave it on the one that seals, for a time ?? 100 lbs plus.... You can pull the starter,and pry agenst the starter ring, maybe both ways?? or best with the pan off .... and more socking .... MMO.... OLD....BILL
OLD...BILL is offline   Reply With Quote
Old 09-23-2013, 03:20 PM   #7
Ralph Moore
Thanks Bill I'll give that a try. I freed up a 1931 Willys-Knight sleeve valve engine a few years back using MMO, soaked it for a few months(your in no hurry when winter has set in), and then put a prybar on the flywheel.
Thanks for the info on the heads 41Ford.
