Old 09-19-2019, 01:22 PM   #1
1936 ford pickup
Default Wiper Motor Mtg. Hardware needed....
Hello,
I have my '36 Ford pickup and need the Vacuum Wiper Motor Mtg. Hardware.
I had the Vacuum Wiper Motor rebuilt by Ficken Wiper Service.
Ficken Wiper Service did an excellent rebuild job.
Now I want to install into my '36 Ford Pickup.
I am trying to locate the required Mtg. Hardware.
Does anyone know where I can locate the required Mtg. Hardware.
Thank you,
Bruce in California
1936 ford pickup is offline   Reply With Quote
Old 09-20-2019, 08:10 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Wiper Motor Mtg. Hardware needed....
Try Ficken or another rebuilder.
Old 09-20-2019, 09:01 AM   #3
deuce lover
deuce lover's Avatar
Kent of Clean Sweep in OR 541-923-4319 and Don't tell him Ficken did your wiper motor.
Old 09-20-2019, 09:12 AM   #4
nelsb01
nelsb01's Avatar
To answer your question --- the wiper is installed through the hole above the windshield. There is a special chrome washer (different than 1936 passenger vehicles) and then a nut. That is all that holds the wiper mechanism in. The rubber hose used for the vacuum that is needed to work the wiper runs down the drivers side A pillar (post) and under the dash and then through the wiring loom hole and to the intake manifold.
The special washer is hard to find. You may have to run a classifed wanted ad.
nelsb01 is offline   Reply With Quote
Old 09-20-2019, 11:45 AM   #5
1936 ford pickup
THANK YOU very much to all of you for your replies back to me, they all helped a lot.
Old 09-20-2019, 07:00 PM   #6
DavidG
DavidG's Avatar
Bruce,
I'm sure you meant to mention the rubber washer encased in the special washer that served to seal the opening in the hole in the body roof.
Old 09-20-2019, 11:04 PM   #7
Don Rogers
Don Rogers's Avatar
There is another major component that you will need to properly mount you wiper motor in your truck. You will need an internal spacer (50-811224) that goes between your wiper motor body and the inside og the cab roof. See images below.
Don Rogers is offline   Reply With Quote
