Old 12-06-2018, 10:00 PM   #1
50B
Default Question
I have a complete model A rear end that is fully rebuilt with new bearings / races / seals with 3:54-1 ring & pinion and it is painted. This includes drive shaft & torque tube. Ready to install, was going to use it in my wife's Vicky but she past-a-way.
Looking for what would be a good value for it
50B
50B is offline   Reply With Quote
Old 12-07-2018, 01:52 AM   #2
J Franklin
J Franklin's Avatar
Default Re: Question
Add up the cost of the new parts and add a few hundred for labor and original parts. Now you should be in the ballpark.
Old 12-07-2018, 06:34 AM   #3
ronn
wild guess 500.
not a big mkt
ronn is online now   Reply With Quote
Old 12-07-2018, 09:59 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Well, naturally it is only worth what someone will give, ...and it also depends on how thorough a rebuild truly was (i.e.: were the housings straightened?, were new hub races installed?, were the spring hanger bushings and the shock link balls replaced? etc., etc.). To have one professionally rebuilt as suggested above using a 3.54 R&P, new axles, machined and painted will cost around $2.3k. The last I knew, a 3.54 R&P with freight was near $500 alone. A hobbyist-rebuilt one should at minimum be worth what the parts are new, but again if no one near you perceives it as a value at the price of materials, Ronn may be correct at $500.00.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
